tire installers tire rack?
Car: 1989 ws6 transam
Engine: 5.7 tpi
Axle/Gears: stock gears limited slip posi
ok im going to get new tires for my t/a due the fact that the p/o replaced them one at a time they are 4 different tires at 4 different stages of wear
I want to know where in Massachusetts or southern nh is an installer I can trust not to damage or scratch and mar up my original wheels maybe someone who works on third gen or classic cars also anyone buy through tirerack and use there recommended installers with good experience please let me know I just would lose my mind if these rims got f-d up
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: tire installers tire rack?
visiting a shop and checking out the premises will often give you a clue how they work.. clean shop, new machines and friendly/knowledgeable staff will give you a good idea how they work.
most high end shops have no touch tire machines and will have no issues doing 16s. even back in the day when the no touch machines werent invented people were able to mount these with no issues on conventional machines.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Its not just scratching the wheels you should be concerned with.
IMO, all tire shops should be considered "Dangerous"
That's why I take off two tires at a time and take them in.
Because....... They "don't" know how to lift the car and will crush your undercarriage ,pinch welds and ground effects .
Scratching your paint is not a concern for them while they run around trying to nock it out in record time swinging a 3 foot toque wrench with them..
I have a very expensive paint job and taking in the tires as I suggested "IS THE ONLY WAY", I will do it.
I actualy take dated photos of the wheels before I take them in.
But its your car and your wheels.
Car: 1988 Camaro
A good tire shop is hard to find really. In not in your area but around me there is only 1 shop with in 50 miles that I trust to jack up and change tires on my car. Even still I will not leave the bay when they are doing the work.
I agree with Ron... Most shops are not careful of jack placement, paint or body.
Now there is many shops that I trust to break a tire off wheel and put another one on.. But I will pull my wheels off at home and take wheels and new tires to them... Not my car.
I buy all of my tires online from discount tire direct, summit racing or tire rack. Done that for 15 years now
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wheely Good
Also beware if you have wheels with oval mounting holes such as Cragar SS.
The highly trained professionals at some (other) shops will cross thread at least one stud as they don’t know how to hold the wheel in the correct position and finger start the nuts.
Happy Racing !
If You’re In Front Of Me DON’T Slam On Your Brakes Just Because Someone At The Head Of The Pack Is Spinning
Happy Racing !
Terrell351
06-13-2021 01:13 PM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
