Added Hawk's 17" GTA Wheels to my RS
Car: 1992 Polo Green RS Z03
Engine: L03 - 5.0 Liter V8 TBI
Transmission: MD8 – 4 SPD Auto
Axle/Gears: GU2 - 2:73 Ratio
Didn't want to mess with my original wheels and tires or my 92 RS since they are pristine. But was not comfortable driving on 23 year old tires.
So this was my solution. Very happy with the results.
Running BFG 275/40ZR17 tires. Mounted up great, did need to use the supplied spacers on the front since the rim contacted the tie rod and a small flange on the front strut.
CKone (12-13-2019)
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Added Hawk's 17" GTA Wheels to my RS
How about some shots from the front and rear so everyone can see how they look?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
They're ready in gold now?
Some better glamor shots.
CKone (12-13-2019)
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
So wait, you have to use a small spacer to use there wheels in a 17" size? sounds odd.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Hence a small spacer.
After all, it is easier to use a small spacer if the wheel has too much offset, than be screwed if the wheel has too little offset... You can't "un-spacer" a wheel to give it more backspacing.
Phil,
That is due to Hawks trying to fit these wheels to several different applications - 2nd gens especially. That is due to the 5.5" BS, when around 5.25" is what you need to avoid the tie rods (like the Firehawks). Odds are you wouldn't need them if you installed a BBK that pushes out the hub surface a bit.
Phil,
the brake upgrade would fix that problem, that didn't cross my mind .
wheels look pretty good though
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Congratiulations!
That's one of the nicest combinations I've ever seen.
I think that was the color my old 92' GTA had (Medium Green Metallic) or am I wrong?
Love it
And those wheels..... it's more and more likely that I will equip my 89GTA with them.... they simply look perfect.
Love it
I just received the same color wheels for my 'Bird on Friday but disappointed to NOT find my wheel spacers. I checked everything, every piece of packaging and under every piece of cardboard. stinks to know I'll probably have to have them in order to run the wheels. What thickness are they and are you running the stock lug studs?
They are about 1/4" thick and work fine with the stock studs.
Car: 1991 Camaro Rs/Z28 clone
Engine: 5.3LSX
Axle/Gears: DTS 12 Bolt 4.10
Your car looks amazing with those wheels, by far my favorite color for third gens
Car: 1992 Formula 350
Engine: 5.7 L98
Its amazing how those wheels can make a car pop. I've seen these on Monte Carlo SS's and they look great as well
Moderator/TGO Supporter
To all those who installed the 17" GTA wheels and used the spacers, did you have to use longer wheel studs?? My wheels I got from Hawks also did not have the spacers. Although I will be upgrading my brakes very soon though so I might not need them it sounds like.
I have mine, too! I'll snap some pictures with them on the car as soon as the roads dry up so I can get it out of the garage. I REEEEEEALLY love the way they look... they fill the wheel wells nicely with the additional tire width, and the lower 40 series tire sidewall looks fantastic!
Are you sure you have stock studs?? I am just asking because I put my wheels on with the supplied spacer and the nut is only 3-4 turns on the stud. In my case I will definitely have to use longer studs. New wheel vs old wheel in pics.
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Axle/Gears: 2.73 going to 3.08 or 3.23
I like it so much that I bought original GTA 16's last month for my "non Z03" RS with the Heritage Polo Green with Lt Beige color combo!
Camaro inserts for wheels will be added this week.
Looks Great
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
Just saw this looks great.. love to see them on my Iroc
#45
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Hey I wonder how these would fit on a third gen with a ls1 rear.. I have GTA wheel on my ls1 swapped rear and I hate how they stick out... I heard that these sit in a inch more than the stock GTA wheels... will these somewhat fix that wierd look from the ls1 rear being several inches wider on each side.. would like to know.. I absolutely love these GTA rims..
#47
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I just love me some Green Chevy's. I don't know why but I could never paint mine green, yet I love the crap out of the looks you guys pull with them. Love the paint, love the wheels, great combo good Sir.
#48
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Looks Killer
Another consideration for my Project
#50
colton_carlson
03-08-2019 12:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
LT1Formula
11-16-2015 01:13 PM
