18x11 in rear?
Old 10-01-2015, 12:46 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
18x11 in rear?
Guys,
Does anybody know if 18x11 will fit under the rear with a 6.5 inch backspace? I have been trying to get 18x10.5, but the Forgestars that I want don't come in that size. Only 18x10 or 18x11.
I have a racecar so I don't mind lots of BFH and even some trimming.
I'm thinking OFFSET +13 (=6.5in BS ) up to OFFSET +19 (=6.75BS)(because I can move the wheel OUT with spacers to get it away from the body and bumpstop)
I have adjustable panhard bar so the lowered car is already centered..
AND I don't mind rolling fenders...
thoughts? if this works, I will publish this for everybody to stuff BIG 315 under the rear...
Old 10-01-2015, 07:36 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Re: 18x11 in rear?
After taking a bunch of measurements with my Wheel Wizard, i don't believe 6.5 is possible. I think i'm going to need to go with 6.375 BS (or 9.5MM offset) and then adjust it outward with small 2MM spacers (or 5mm spacers) to get the wheel away from the inside fender. i don't think it'll tuck, but it will be close and I can roll the fenders. I don't think there's any other choice, but speak up if I'm off on these calculations.
Old 10-05-2015, 08:18 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Re: 18x11 in rear?
i'm going to get this all figured out and then i am going to publish my setup so that everybody can order their 18x11 wheels in the rear and 18x10 up front...
Thanks for ALL the support from my thirdgen.org friends!!
Old 10-06-2015, 12:51 PM
dannyboyemt's Avatar
Car: 89 RS,02 WS6 M6,08 GMC Sierra SLE
Engine: ZZ4HCI, LS1, LY5
Transmission: T5/T56/4L60E
Axle/Gears: 323,342,373
Re: 18x11 in rear?
Hey Brian,
I am currently running 18x10.5 with 6.5 inch back spacing. I have a 315s mounted, as well have done the BFH mod. If i could do it all over again i would have gone 18x11. My rear wheels and tires are flush with the fender(but not tucked) and will have to be rolled. I dont see why i couldnt fit a 18x11 in the back with slightly more back space. Demensions of the rear end is stock. Hope this helps.
Old 10-06-2015, 12:58 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Re: 18x11 in rear?
Originally Posted by dannyboyemt
Hey Brian,
WONDERFUL INFORMATION. Thank you so much for sharing with me. I will let you know how it goes.
Old 10-13-2015, 12:33 PM
scholtmj's Avatar
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Re: 18x11 in rear?
11" wheel needs 7" backspacing to tuck under the rear fender. Cut off the bumpstops, hammer the front inner fender.
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
customblackbird
08-15-2021 10:16 PM
Vintageracer
01-10-2020 05:33 PM
Bstrang6
Brakes
08-24-2015 06:45 AM
Quick Reply: 18x11 in rear?
