WHEEL STUDS!!!!!!!
WHEEL STUDS!!!!!!!
I have a 1991 Camaro Z28 5.0. My question is what size are the replacement studs I would purchase, and what would you recommend. I was actually hoping to put some racing ones on for the road courses, and Auto X. Just need some help on what size and brand. I would like them to be just a tick longer then the stock as well. Thanks in advance!!!! Shawn
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: WHEEL STUDS!!!!!!!
Stock stud size is 12mm x 1.5 pitch.
You can upgrade to 1/2 studs (12.7mm) or even 9/16" - whether it be OEM length or extended shank. But for extended you will need pass-through lugs as OEM type lugnuts won't work.
