Weight of factory 88 Formula wheel
I have searched for this but really didn't find a definite answer. Anyone know the weight of the factory Formula wheel?
Re: Weight of factory 88 Formula wheel
Car: 89 Firebird
Engine: 355 TBI
25lb. Sold a nice set for scrap aluminum is how I found out. I think the GTA style wheel was around 19lb.
Engine: 4++,350 & 305 CIs
Which is funny that the wheel weighs as much as a 15x3.5 Draglite with 165r15 tire...
Yes it is. Definitely an area to lose some weight. I emailed Billet Specialties about Street Lite wheels.
17x7 = 15.6 lbs
17x9.5 = 18.4 lbs
17x7 = 15.6 lbs
17x9.5 = 18.4 lbs
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I'm going to suggest that instead of the 7"/9.5" wheels, you go 9.5" on all 4 corners. Your handling and braking will improve significantly and also you will be able to rotate the tires.
