Blasphemy!!
1 Post
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Blasphemy!!
I know what many will say, but I'm going to post this anyway. I came across a ridiculously good deal on a set of 17" wheels.... Mustang wheels.... I know, I know, who would put Ford wheels on a chevy? Well once the center caps are off, they look just like Torque Thrust II's. I mounted them using 1.25" adaptors, and I think with some modified center caps they will look pretty slick. I'm willing to take the ridicule... Bring it on!
I haven't set the car down on them yet as I'm rebuilding my suspension.
1 Post
Re: Blasphemy!!
Thanks! I like them more than I was expecting. I'm looking forward to seeing them once I figure out the ride height and get it on the ground.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Blasphemy!!
I personally don't think its bad, but how heavy are they? 8" wide?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Blasphemy!!
IMHO,the only aspect that is a problem with the "wheel" is the weights on the outside.
Maybe on a old set of steel truck wheels but never on a nice set of aluminum car wheels.
I always tell a tire shop, weights on the inside only or they will be buying me a new set.
But.......
A wet rag and some tire shine please.
Just yank-en your chain bro.
But.......
Car: 1991 RS
Axle/Gears: 4.11
Re: Blasphemy!!
I have absolutely no problem with people using ford things on their GM cars, or GM things on their Ford cars. Use whatever is best. and particularly in this case they look good.
If anyone gives you crap about it, tell them to **** off.
1 Post
Re: Blasphemy!!
But.......
But.......
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 Let's Go Brandon
Re: Blasphemy!!
Since when does the Mustang and the Thirdgen F-body have the same wheel bolt-pattern?
1 Post
Re: Blasphemy!!
I bought a set of 1.25" billet spacers/adaptors from Summit. They were the perfect width to run the ford wheels with the correct bolt pattern. They were about $90 for a pair, so I have a grand total of about $300 into this setup.
1 Post
Re: Blasphemy!!
Finished up with the suspension redo, so I can finally get a look at these wheels at the new ride hieght. Pardon how dirty the car is. Been sitting on jack stands in the garage for almost a year.
1 Post
Re: Blasphemy!!
Sorry, just saw this. I'd say for weight they are pretty comparable to the stock 15" wheels. I haven't weighed them to know for sure. And yes they are 8" wide. They have a back spacing of 5.5" so the 1.25" spacers work perfectly. They currently have 235/55/17 tires, but I will likely be switching to 245/45/17.
Engine: TBI,5.0
Re: Blasphemy!!
They look really good and if you don't tell any one there "Ford" most will not know. Just say there Torque Thrust 2 replicas and leave it at that.
That's what they are any way.
Also, I live down the road from a Truck Stop that has gravel roads so I know a thing or two about dust and dirt in the air.
This is an item that I truly believe in.
I use it a lot and don't really know what I would do without it.
California Duster = https://www.walmart.com/ip/The-Origi...uster/14294929
Just follow the "before you use it" directions.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Blasphemy!!
I like most people used to have a GM vs Ford vendetta in the old days. But now? With our cars being old and out of production, I just smile and make immediate new friends when I see somebody with a Fox body Mustang of the same vintage as us at a car show.
I've got no problem with those wheels. And actually quite like them. Easy to clean with a nice strong look to them. Good buy.
1 Post
Re: Blasphemy!!
Looks really good on the Grand Prix! I finally got the car pulled out of the garage for a good peek at the new stance. Eibach Sportline springs, complete Founders Performance rear suspension components, Energy Suspension bushings throughout the front and new KYB shocks and struts. Pretty pleased with the results.
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Re: Blasphemy!!
Pshh who gives one if its ford on chevy or chevy on ford, the new camaro zl1 has a 10spd auto built by gm and ford together haha
Re: Blasphemy!!
They look good! I had a set of aftermarket ones on my 80 Camaro for a while. I just adapted wheels I bought for my 98 Riviera a few years ago to fit on my 87 IROC.
Re: Blasphemy!!
They look GREAT.
Why didn't anyone ever think of this before?
Re: Blasphemy!!
Liking the Sport Coupe. (Former Barrie, ON resident too. Drove through your town many times on my way to the cottage.)
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
Re: Blasphemy!!
You may not care but your wheel bearings do Id never do this in a high performance application!
Re: Blasphemy!!
Ha! I have friends in Goderich. (And I practically lived in Grand Bend as a kid).
The Toronto signage has been replaced with Alberta landscape now.
Did you get your speedo issue figured out? I read your post and just went through this.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: Blasphemy!!
Did your car slow down any with the Ford wheels lol.
