How Far is your screw into the AFPR?
Old 05-15-2002, 06:35 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
hey, how far should my screw thing be up into the throttle body? Mine is all the way pushing onto the fuel line inlets so its a ways up there. Whats everyones else? I don't have a fuel pressure gauge so I can't tell where it is at right now.
Old 05-15-2002, 07:59 PM
snflupigus's Avatar
its pushing into your fuel line inlets? what? explain. dont mess with i without a guage.
Old 05-15-2002, 08:09 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah, u know the things that come out of ur throttle body that u screw ur fuel lines into? The **** thing is up at those. Do you get what I am saying?
Old 05-15-2002, 08:47 PM
snflupigus's Avatar
i guess i get it. what really matters is how far it is stickin out inside the cup. which you cant see much, sooo. you will have to get a fuel pressure guage. sorry to tell you.
Old 05-15-2002, 09:47 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Give me 40 bucks then u fat peice of crap from semese street. I plan on getting that one from autozone for 40 bucks.
Old 05-16-2002, 06:39 AM
snflupigus's Avatar
paypal ok, ya Japan-imation freekaziod?
get a job.
Old 05-16-2002, 11:35 AM
JPrevost's Avatar
Car: 91 Red Sled
$30 and you can have a 0-30psi gauge. $20 for the gauge and $10 for the fitting. I just sliced my rubber line that's just above the power steering box. Very easy to install so long as you know how to cut a rubber hose and tighten down a couple hose clamps. Oh yeah, and use soem teflon tape on the gauge!
Old 05-18-2002, 09:18 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
HEY! Leave Vegeta alone! DBZ rules snuf - YOU can't shoot pure energy now can u?? lol. One question - since this is about fuel pressure - i've been toying w/the fuel pressure regulator on my Holley tbi and i'm really stuck. My plugs come out and they're very clearly running rich (the tips are tan but the rest of the plug is sooty) so i decided to back off 1/2 a turn on the tbi unit - but now the car's throwing codes once its warmed up (it seems to happen when the tranny shifts and drops rpms down to 1,500 and the engine bogs - i drove the car home from a friends last night and the check engine light kept coming on, fading away, then coming back on. I brought the screw back in 3/8 of a turn and it seems (seems i say) to have gone away but i'm kinda boggled b/c now the car throws a code if i get into it b4 its completely warmed up. I dunno if i'm running rich or if Tbi cars just like a lotta fuel. *shrugging* I've still got the 305 comp. so i'm hoping thats part of the problem. Maybe I should look into getting a 350 knock sensor and 02 sensor? Or maybe i'm just not used to sbc's - i can't believe my parents made my first car a honda! ARGH! DIRTY!!! lol. Thanx guys.
TP
Old 05-18-2002, 12:33 PM
JPrevost's Avatar
Car: 91 Red Sled
Find out what the error code is and replace the problem part. We can spend weeks telling you to replace the o2 sensor, the MAP sensor, and all this other crap but in the end it would just be cheaper for you to build the winaldl cable and borrow a friend laptop and run winaldl.
Old 05-19-2002, 09:56 PM
Tallboy's Avatar
hey PREVOST
where do u get pressure gauge and fitting?
do u have the part number and/or size?
did it fit well or was it a tight fit?
dont look like u can bend the feul lines much or move them around
Old 05-19-2002, 10:37 PM
JPrevost's Avatar
Car: 91 Red Sled
Jegs: 656-101 that's for the 0-30psi fluid filled fuel pressure gauge is $19.99 and the fitting required to tap into the rubber flex line on the drivers side frame rail (above the power steering box) is part number 720-2975 that's ALL you need.
3rd gen money
10-11-2019 09:57 PM
2012sergen11
10-13-2015 07:38 PM
Reid Fleming
10-10-2015 09:56 PM
LT1Formula
10-08-2015 08:34 PM
Quick Reply: How Far is your screw into the AFPR?
