best cam for stock 305
i have a stock 88 tune port 305 and i want to put a better cam in it. the engine is in an 84 S-10 pickup. when i did the engine swap i pulled the engine, tranny, computer, and wiring harness. so anthing for a fire bird will work in this (except for suspension). i want more from me engine but i dont know what cam to use . the tranny is a 700r4 with a shift kit and the stock stall converter. i want to keep the stock converter and i want to know what's the biggest cam i can use? i plan on doing other mads to the engine in the future ( runners, throttle body, intake, pullies, adjustable fuel pressure regular, and anything else i can think of) it all ready had shorty headers. if anyone could help me out it would be greatly appreciate.
thanks in advance
jared
thanks in advance
jared
Car: 87Z
Engine: ?
Transmission: A4
Stock LT1 or after market of the same grind (just cost more) the 305 responds very well to them. I went from a 15.4 to a 14.6 with a small B-body cam. I know have two f-body lt1 cams in my possesion. We will see how well they work.
Car: 04 GTO
Transmission: M12 T56
If you're going to do all the work of a cam swap, why would you go back in with a stock GM grind? Sure it'll work better than a peanut cam, but beyond that, it's not a performance grind by any stretch of the imagination.\Wouldn't you rather buy the cam you want and only have to do 1 cam swap, rather than save a few bucks and count the days till you have to rip the whole engine apart again to get the stock GM cam out.
Car: 1991 Corvette Coupe
i need your advice on my 350 buildup
i am going to be using 305 (416) heads until i can afford better heads
what would be a good cam for me to use?
i am planning on Pro Lightning heads when i can afford them
this is a daily driver, so i need something that will idle, lol
i also want to burn my own custom chip for it
i have a 5 speed and a 3.42 rear so theres no converter to figure into the equation
thanx for your help
oh yeah, my comp ratio is gonna be 10:1 with the 416's and when i switch over to the Pro's it should be about 9.35:1
jared i was in your boat last winter with my 86 IROC. before any cam swaps i suggest headers and a good exhaust if you havent done so already. i installed a lingenfelter cam with 214 224 duration @.050. and somethin like .444-.465 lift in my 305.(that is a flat tappet cam, you could run a bit more with your roller setup) i also ported the plenum and added a throttlebody air foil. i love this cam, it idles kinda choppy, but above 1800 rpm makes alot more power than my stock peanut cam. the only problem i have is my stock torque converter stalls too low, hence my 93.5mph trap speed with only a 14.8 ET. i am installing a converter this winter to rectify the situation, i think the motor has enough power to get the car to a 14.5 with the better converter, i think that is pretty respectable for an otherwise stock 305. i strongly suggest the cam i listed and a higher stall converter. those 2 mods along with at least 3.23 gears will totally change the truck. i think others here will support me on that. cam, converter, and gears can totally transform almost any vehicle. if you want a noticeable gain, do the cam and converter too.
i allready have shorty headers and dual 3 inch exaust all the way back. i think the LPE cam will prolly be my best bet seeings how i have the stock converter. where can i get it and how much? thanks
Car: 87Z
Engine: ?
Transmission: A4
Ok here is my case in point. 1MeanZ has an after market "performance grind cam" and is running .8 and 3 mph slower than my very mild LT1 cam. I'm sure that cam is $200 or so, my current cam was FREE and the two I have now cost me $15 each. All he is looking for is to improve a 305, moderation is the key to a quick 305. I have searched and read just about all post about the 305 for the past 2 years I've been a member of this board. Just about all 305 with higher duration and lift cams are slower than my little 1996 B-body LT1 cam. I now have cams from a 95 and 97 Z28. specs as follows 201/.447 intake and 208/.459 exhuast LSA of 117. I run the stock chip and the car is a blast to drive. But if you want an after market cam go for it, this is my real world results.
hummm....i dont know what cam to get now. i think im going to have to do more research. on one hand i have a factory GM cam in a different engine. and on the other i have a aftermarket cam. what a perdicament
Car: 87Z
Engine: ?
Transmission: A4
Car: 04 GTO
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
If you want to remain basically stock. The Summit 5000 cam brags 30 to 50 HP increase. Sales for I believe $159. Designed specifically for 87-89 TPI's
well new87 my car may be slow by your standards but as i stated that was with the stock converter and stock suspension and street tires. i see that you had slicks, drag shocks, and suspension parts. i will let you know what i run this spring with my converter and suspension work. dont waste your time putting a cam as mild as an lt1 cam. it is a waste of time. it is not enough bigger than the stock cam you have to even **** with. and as i stated, we will see what my 305 does with a converter and the same suspension work that new87 has
Engine: 350 HO
Axle/Gears: 336
Here they are as listed on Summitracing.com site.
Part #SUM-G5000. I believe this is a non-roller
type cam.
Summit Racing Equipment
Product Line: Summit TPI Cam Kit
material:Cast Iron
Up to 40 more horsepower for your TPI engine
Chevy: 1985-87 Camaro 305, 350, 1985-87 Corvette 350;
Pontiac: 1985-87 Firebird 305,350, 268/278 degrees duration TPI camshaft kit
Advertised duration: 268 intake/278 exhaust
Duration at .050 in. cam lift: 204 intake/214 exhaust
Gross valve lift: .420 in. intake/.442 exhaust
Lobe separation: 112 degrees
Stuffed in an '86 IROC Camaro with a 305 TPI motor and an ADS Super Chip installed, our TPI cam kit made 40 extra horsepower and knocked almost a full second off the IROC's 0-60 times--and the computer worked perfectly. This kit includes the cam, lifters, springs, retainers, and lube. If your car has more than 30,000 miles, we suggest you add a new timing chain.
type cam.
material:Cast Iron
Engine: 350 HO
Axle/Gears: 336
Yes, CompCam #CCA-08-300-8 for basic stock engines
1987-1998---305,350
You want to go bigger, check it out.
Specifications:
* Advertised duration: 262 intake/264 exhaust
* Duration at .050 in.: 206 intake/210 exhaust
* Gross valve lift: .450 in. intake/.480 in. exhaust
* Lobe separation: 112 degrees
* RPM range: 1,000 to 5,000
* For factory roller engines with stock TPI and computer
1987-1998---305,350
Specifications:
