DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
Innovate Wideband Input to Gen 7 DFI?
Old Mar 16, 2004 | 09:50 AM
KAA's Avatar
KAA
Has anyone successfully used the Innovate LM-1 as a wideband input to the Accel DFI Gen 7 ECM? I'm all for experimentation but, if it's been tried already and found to not work, I'd like to save some time and wire cutting. From what I've been able to find about Accel's wideband unit, it sends a 0-5v signal to the ECM. Since the Innovate unit is programable, I don't see why it wouldn't work. Unless there's some other kind of magic that Accel's box makes? Thanks!
Old Mar 17, 2004 | 05:55 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
It'd be tough to do right now unless you program the WB to emulate the A:F vs. Voltage curve of the DFI unit...
... However, an updated version of the DFI calibration software is coming very soon that will allow you to program the Gen 7 to recognize a generic linear curve of 0 volts == 10.0 A:F and 5.0 volts == 20.0 A:F. If you program your WB to yield that function, you will be able to set up your Gen 7 to read it.
Old Mar 17, 2004 | 10:00 AM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
Where can you get the info on the new updated software?
Old Mar 17, 2004 | 11:00 AM
KAA's Avatar
KAA
What is the A/F vs. voltage curve of the DFI unit? I thought it already was 0-5v 10 to 20 AFR linear?
Old Mar 18, 2004 | 05:58 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
The DFI unit is in the 0-5 Volt range, but the curve is not linear.
The new software will be labeled version 4.0, along with a firmware upgrade. You don't need the firmware upgrade for the wideband stuff, just the updated calibration software which will be a free download once it's available.
Old Mar 18, 2004 | 02:14 PM
KAA's Avatar
KAA
That's interesting. Well, I'll be anxiously awaiting the software update. Thanks for the info!
italiano67
Dec 11, 2016 09:21 AM
neekolzun
Aug 24, 2015 04:59 PM
IROCThe5.7L
DIY PROM
Aug 10, 2015 11:24 AM
marcusaw
Aug 10, 2015 08:13 AM
