Holley BLue fuel pump relay?? need Help
Old 09-23-2004, 12:47 PM
Guest
Guest
Posts: n/a
Holley BLue fuel pump relay?? need Help Trickster!!
ok i'm trying to wire a relay to the fuel pump on my car but i don't have a wireing diagram so people tell me if i have this right
pin 30 on the relay goes right to the battory
pin 87 goes to the hot wire on the pump pin
86 goes to the IGN. on power in the fuse box (or in my case a
toggle switch)
pin 85 is ground?
pin 87a is not used.... does this sound right?
Old 09-23-2004, 02:25 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What kind of relay are you talking about here. That definitely isn't the stock fuel pump relay with pins like that.
Old 09-23-2004, 03:03 PM
Guest
Guest
Posts: n/a
this is a full blown race car nothign stock the relay is a 30amp 5 pin relay you know the same kind that you get to the fan kits you can get where you put the temp rod in the rad. and it was turn the relay on to the fans.... same idea.... what i'm trying to do is other then haveing the the babtorty goign to the fuse box then to the toggle switch then back to the pump that was only 12" away from the battoy i want to use a relay so i get more volage to the pump
Old 09-23-2004, 07:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'll e-mail you a wiring hookup page....shoot me a PM with your e-mail address and i'll let you have it.
Old 09-23-2004, 09:10 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
That a pinout for a standard Bosch relay.
85 & 86 doesn't matter for polarity.
For your application, this is what you're wanting...
Old 09-23-2004, 10:10 PM
Guest
Guest
Posts: n/a
Yea thats what i was thinking just wanted to make sure. i didn't want to burn up the pump .... not like it matters i have two of them LoL
Frozer!!!
01-19-2024 04:55 PM
RazorN8
01-07-2022 11:44 AM
Glowsock
08-02-2020 07:36 PM
Bryan F
08-18-2015 02:28 PM
Kaweh
08-09-2015 02:54 PM
Quick Reply: Holley BLue fuel pump relay?? need Help
