Timing question with photo, is this 2* advanced?
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
EDIT The picture has been swaped out with the actual correct numbers for easier use/verification. If some part of the thread doesn't make sense, now you know why EDIT
The old setting is what the car had always been run at, ever since I bought it.
I bought a timing light and advanced the timing, to this setting. The pic explaines all. I tried 4* but when I gassed it and then let off (in first gear) I heard a quick noise from the exhaust. It sounded like a backfire? Not sure really. So I set it here, at ~2* and it feels great. From a roll of 5-10mph when I give it WOT it'll spin the tires, it never had that power before! I put in 91 octane gas....everything sound good? I was afraid of going with the 4* advanced because I did'nt want detonation. Maybe the car had been driven 150,000+ miles with 2* retarded timing and coulden't get used to a 6* change? Just wanted to be sure everything's ok here.....Thanks.
Ah....so it was really retarded before then...no wonder it feels so much better...
The only thing is....I'm in park, idle is at 750rpm and i'll step on the gas a bit, real quick and bring the rpms up to ~3000 and let off....when it comes back down it'll stop at ~1500 for a second then slowly come back to idle...Is that normal?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Great, thanks guys!
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
Car: 96 Silverado/99 Suburban
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
That picture is awesome! Seriously I'm adding this thread to one of the stickies at the top, that picture will help SO many people figure out where to set the timeing in their cars! As far as the thread itself, this does belong in the tech/general board, so off it goes... Thanks nidyanazo!
Bruce (90RS305)
Bruce (90RS305)
Glad I could help, but it was you guys that solved my question. So thank you guys.
Car: gmc jimmy
am new here,like to ask a question.
I have been thinking that I have been having problems timing my 305tbi fuel injection.
this is what happens.....
when I put the timing light on the mark (and yes I have done everything your suppose to time it) and when i crank the throttle, the timing mark RETARDS THEN ADVANCES.
Is this normal????
yes the motor is warmed up,and yes i disconnected the wire to the distributer,yes Ive done everything your suppose to, to time a fuel injection motor.
I have worked on many NON computer motors and I never had a timing mark "retard then advance!" It always just advanced when ya crank the throttle.
So as ya can see Im alittle baffled about this.
I have replaced all sencors,msd distributer is new,new HOLLY TBI, mild cam,194 heads, lifters, rockers push rods,daul exhaust.
So any info would be of help....alot! this truck is driving me nuts! lol
Is this normal????
Car: 82 camaro z28
Engine: 305 cfi
Transmission: th 200
I know this is an old thread but im having trouble timing my 305 correct me if im wrong but the stock timing is 6 degrees retarded and according to the pick 6 degrees retarded is between the round circle which is suppose to be 0 and the first peak? Also there is already a chalk mark on the crankshaft but it is way off the scale and is not even close to that piece of metal. Do i draw a new chalk line and where. Thanks
stock is never retarded. it's either advanced or at 0. It should say what the timing should be on a little sticker underneath your hood.
Make sure you're timing with the #1 spark plug wire using an inductive timing light.
And, you shouldn't have chalk lines anywhere. It's a notch, groove, on the balancer.
You should be on the jagged teeth, nowhere near a circle.
Car: 84 camaro z28
Engine: '89 L98 converted to CC Quadrajet
Transmission: '89 700-R4
so where would 6 degrees advanced be on the first picture on this post
Read the second post in the thread. There's also a number etched into the metal tab along with a line. You can't see it from the picture, but it's there.
Vader's picture shows it as well.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think knowledge is power, so here's another picture, maybe it'll help, slightly better angle:
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Call me dumb here, but if the balancer shifts how exactly could you tell what the timing is. My car works like crap at 2 advanced, and even worse on 0. If I advance it to about 8-10 it works fine!
What would be the best way to tell???
ANy sounds that I should be listening for???
Car: 1982 Trans-Am
if your balancer ring has slipped (much more rare then people say), then you're out of luck. You have to go by ear, until you can replace the balancer.
As you bump up the timing, your idle speed increases, and you have to lower your idle speed screw. If your throttle blades are too far closed, you may end up with an off idle flat spot.
8-10* is a good place to be. (edit, this is kinda dependant on many things, cam mainly, but also, if your computer controls the timing, or if it's all you.. .)
YEah, its an LO3 by the way. When I got the heads re-built and put them on I adjusted the car by ear. It sounded pretty close to 0 degrees, so I left it. Went and passed emissions with flying colors.
Little did I know that my balancer was showing 8 advanced. I don't think I coul've passed emissions with 8 advanced??? She likes that.
At 0 it starts pretty hard.
Car: 84 camaro z28
well i set it just a tad below 6 degrees to start off. should i bump it higher? there was no audible pinging, but my harness didnt come equipped for a knock sensor
Car: 1982 Trans-Am
put it in a high gear, and lug it up a hill. Listen for pinging. If it pings, back it down, if not, bring it up. Until you get pinging , then bring it back a few degrees.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Or, for a manual trans - come to a stop, throw it in 4th gear, and drive away with the throttle wide open... if it pings, back it off a bit.
Car: 1982 Trans-Am
Car: 1982 Trans-Am
like you've got a box of pop bottles in your trunk. (from what my cousin told me, i've never actually heard it...)
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
sorry if this is out of place guys but i replaced my timing cover with one that doesnt have a timing indicator on it and happened to throw the old one out before setting my base timing(its a project) Basically im trying to find TDC so i can tighten the rockers and every manual i look in explains the way of looking through that indicator....i know i will have to do this again when im setting the base timing....how can i find TDC?
Car: 86 iroc, 84 z28, 92 firebird
Engine: 355, 350, 305 tbi
Transmission: custume 5 speed, automatic, 5 speed
Axle/Gears: 373s in the bird
A trick you can use if really needed, you can pull spark plug one, roll up a small paper ball and stuff the hole. crank the motor till you hear a pop, which is the paper blowing out, and check your rotor under your distribitor and see if the rotor is pointing to number one cylinder. If it is your now at tdc.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I had another vehicle, a 2.8 truck about 10 years ago, that the balancer slipped. My uncle overrevved it (5 spd) and threw a rod.
-- Joe
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Pinging sounds like you are shaking a glass jar full of gravel. You'll know it if you hear it.
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
ok quick one for ya setting timing for first time, car wont start, have someone crank while holding timing light on the balancer, is this acurate?
Car: projects.......
Car: 1991 RS Camaro
Engine: 305 TBI LO3
Transmission: Stock
Re: Timing question with photo, is this 2* advanced?
i know this is an old thread but i'd like to know if i did advance my timing would i have to run a higher octane of fuel than the regular 87 to keep from knockin?
Car: 1988 RS Camaro
Axle/Gears: Stock
Only if it is knocking or keep advancing the timing until it does knock then back it of two to three degrees, and you should be good to go
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
Going to try to advance a tiny bit without a timing light. Can someone give me an idea of how much I have to move dist. cap counter clockwise for a degree or two? Is the bolt that I have to loosen to move the cap easy to get to? Do I need a special tool? Sorry for dumb ?'s...lol.
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
You will need a distributor wrench to get to it
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Car: 02wrx/88 rs
yeah just go there and ask for one. Its a tool almost in a zig zag one side is 9/16 the other is half
Linson
08-21-2015 02:12 PM
