will a stock TPI setup go on a 400 sbc
Car: 1987 Trans am 5.7 TPI
Engine: 5.7 TPI
the subject kinda speaks for itself. just got off the phone with a friend and he is willing to trade me a 400 small block. can i get my stock TPI unit to go on it?
Engine: 5.7 TPI
i don't know what heads are on it. with the bigger CI i would need bigger injectors right?? and would my 700R4 hook up to it?
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
well that tpi is just another intake manifold, it will bolt up to any small block that does not have vortec heads. bigger injectors would help, 24# or so. and 700r4.. do you mean bolt to the engine? as far as i know, it should.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
Actually if you are running the older style heads, the 2 inner intake bolt on either side are on a different angle. Now if you have an early TPI (pre 1987) intake you will be fine. Now you can also oblong the bungs on the intake to make it work (post 1987), but it looks a bit backyardish to be honest if not done right. 24# injectors should work fine, but you have to take many things into consideration when mixing and matching, cam, TB cfm, compression ratio etc.
Engine: 5.7 TPI
these are the things i wanted to know my tpi is an 87 and i'm sure the 400sb is old as sh*t but it is clean up with new rings and seals i think it should be alot more than the 350 i have now. also would the 400 kill my 700R4?
Engine: T.P.I L98.
The 700r4 is a good tranny, unless your going to be putting out like 500hp or more you should be just fine. The 454SS Trucks run pretty much the same 700r4 trans. Now you may want to put a Corvette servo in there to help out some, but other then that you should be OK.
Engine: T.P.I L98.
Engine: T.P.I L98.
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: will a stock TPI setup go on a 400 sbc
Car: '85 Camaro
Engine: LG4 305
If the questions are will it bolt together properly and can it be tuned to run smoothly, sure. I don't know that you would make 50 more HP because of the displacement increase, but it is worth a shot. I the meantime start saving up for one of those asftermarket pieces.
Jason
Jason
Engine: 5.7 TPI
Engine: T.P.I L98.
can i take a pre 87 manifold " http://cgi.ebay.com/ebaymotors/ws/eB...category=36474 " and use the rest of my 87 tpi unit?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
A 400 with TPI will be the closest thing to a gas-burning diesel you'll ever find.
You'll make about 200 horsepower and 500 ftlbs of torque. The TPI will literally choke the **** out of that motor at 4000rpm and above.
Engine: T.P.I L98.
Car: 1985 IROC-Z
hmmm, well there is a fella up here that goes to the track very often with a stock setup on his 400, Some gasket match work and headers, and he's pulling mid 12's out of his car. If I remember correctly he dynoed at around 300 rwhp and around 480 ftlbs.
Car: '85 Camaro
Engine: LG4 305
Yeah it's okay. Remember that this will not be a rev machine. Set up your plans for as much torque as you can stand as low as you can, gear it that way, and you will have fun. Change the intake and cam, and you'll be flyin.
Jason
Jason
Perhaps a totally stock 400 with smogger heads and a crap cam can't benefit from an induction that breathes better anyway, so maybe the torque benefit of the TPI isn't such a bad thing (especially if this 400 is in a truck), but if that 400 has even a marginal set of heads and any non-stock cam, the TPI is going to be a major restriction.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Just an addendum...
You can use all your stuff, you don't need to buy a new baseplate, you only have to redrill the holes in your '87 manifold, and that's if you use the older style -heads-.
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
