Can I put a LT1 block and heads under my TPI?
Old Oct 20, 2000 | 12:30 AM
jdb8797's Avatar
I am having doubtful thougts about the OptiSpark and the water pump, since they are both cam driven. I was looking into putting a 25K-35K mile LT1 block under my TPI so I can step up to a 350. I'll probably use the LT1 heads also, if I can. Any thoughts?
Jeff
Old Oct 21, 2000 | 11:42 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Can't do it. It's either go all LT1, or L98. pretty much the only realistically useful thing you can swap between the motors are the cams.
Old Oct 22, 2000 | 01:11 AM
jdb8797's Avatar
Thanks for the info, man.
Jeff
Old Sep 19, 2001 | 08:50 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
<font face="Verdana, Arial" size="2">Originally posted by Markolc:
Can't do it. It's either go all LT1, or L98. pretty much the only realistically useful thing you can swap between the motors are the cams.</font>
Wrong........wanna see pics?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Sep 19, 2001 | 10:28 PM
Tas's Avatar
Tas
to put a TPI on a LT1 you'd just have to change the intake bolt pattern, and block off the front thermostat housing. The distributer should go in fine.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 22, 2001 | 01:16 AM
UnderDogRS's Avatar
why would you do that.
the stock 350/305 TPI is fine for a 305(mostly) and chokes out on a stock 350.
now put the LT1 in there and it would choke out faster,like 3000rpm i would guess.
so if you take the time to put a LT1 in go all out and get the newer computer and stuff.
<A HREF="http://ca.geocities.com/zander0710/" TARGET=_blank>
1992 Camaro RS</A>
****In The Work****
94' Z28 Drivetrain(LT1,4L60E,PCM,3.42 posi w/ disk), Walbro 255P fuel pump
!A/C,!cat, !A.I.R, Full Hooker exhaust,Custom program(Rev.b based)
Old Sep 27, 2001 | 01:15 AM
lexussc94's Avatar
My friend has an 87 TA with an lt1 and he is using his original tpi unit. His dist is still in the original location also.
Old Jun 8, 2002 | 08:47 AM
Engine: 4.0L
A LT1 intake will choke out at 3000rpm? What are you thinking???
The LT1 intake will pull to 7000rpm easily, just make sure your vavletrain is up to it.
Old Jun 8, 2002 | 12:26 PM
Tas's Avatar
Tas
Read it again. He was talking about a stock TPI on a LT1 choking at 3000rpm.
Old Jun 9, 2002 | 09:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The way it was written, it sounded like he meant running a complete LT1 with the TPI electronics and it choking out at 3K.
That is what I gathered from the original reply.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
anesthes
Aug 8, 2015 09:37 PM
