New modification done cheap!
Well I decided on Sunday night (Oct 14th 01)
that I could do something to my truck and cure my boredom. So I thought I'll try to place my Small Block Chevy V8 1.6 Rocker Arms on my 2.8 liter V6. I have a V6 Performance book that clearly states that any narrow enough rocker arm from a small block chevy v8 can be used on a 2.8 Iron head. What would not work was a arm with 3/8 or 7/16 stud , because the 2.8 head has a 10mm stud. However I found that on my 1.6 stamped roller tip rocker arms for the sbc could be used if I just reused the pivot washer and the old stud nuts. So I did it, it worked and I am happy with the Increased power.
Considering the cheapest 1.6 rockers arms to be found previously were the Magnum roller tips by Comp Cams at around $169 retail and the only other listed was the extremely expensive crane cams gold full roller at around $310.
I used the crane cams stamped steel 1.6 sbc roller tip rockers which cost $119 . I actually wanted the summit stamped steel roller tips which were only $99 but at the time two years ago when I purchased them the summit ones were out of stock.
If you would like to see a picture or two and read some guy contesting my power gains then go here http://discussions.gmforums.com/show...&threadid=8645
Guys feel free to register and vote on that site adding a tbi/carb section . They call themselves a 60 degree club but dont cover 1/3 of the other engine types! Lets change that.
Also if any of you would like to lurk on the s-series .org board to get information on what other v6 owners are doing, check out http://www.s-series.org/phpBB/viewfo...?forum=21&2674
Also my supercharger pictures for the 2.8 can be found at my website if you remeber my previous posts. http://614streets.com
1992 ext cab S10
173 on NOS, 5153Nos,Black Magic,2030 Crane Cam,11mm Moroso Wires, MSD 6al, MSD Blaster Coil,K&N,Holley Tbi, Edelbrock Headers,40 series Delta Flow,Zexel,Toms 28 spline axles,Hypertech chip, Granetelli 190 lph, Centerforce Dual Friction,Jet pulleys,Spray Bed Liner, Altezzas,Pioneer din 1/2, 01 Vette wheels, Harwood 4 inch hood, and Much more...Just bought a ***eol 2.8 Supercharger!!!!!!
1992 ext cab S10
New rockers are no 'new' mod... people have been doing it since the dawn of time..
Oh, and that new ticking you hear isn't valve lash, it's the rockers hitting the top of the valve covers... 1.6's are a tight fit...
(not flaming)
1985 Camaro SC - 2.8L, auto.
C'mon, spin 'em for papa...
http://www.xenodrgn.f2s.com/Frontright.jpg
(not flaming)
Oops, sorry about that... I didn't see the new Edlebroke valve covres until after I posted.. I take back that bit about the new ticking noise...
Never mind.........
[This message has been edited by 614Streets (edited October 16, 2001).]
They dont "tick" at all, they clear fine. And if you read what I posted I clearly pointed out I used v8 rocker arms to save $. Thats what is new about it.
I'm a fugging retard....
I get it. Heh, sorry about that... man don't I feel stupid...
So what your saying is, that new 1.6 ratio roller rockers for the V6's cost 169 at the cheapest, where you could get V8 stamped steel 1.6 ratio roller rockers for $99...
Huh, I guess that is pretty sweet...
And the ticking... don't ask me... I have no idea what the fu(k I'm talking about... somehow i got the whole 1.6 rockers thing confused with the poeople who wanted to use fiero valve covers on thier cars, and still I'm not even sure thats what it was... someone, somewhere along the line on this board was saying they had a tick under the valve cover because something was hitting it...
I'm sorry, forget this confused little boy even posted.
Thanks though, for pointing that little mod out to us...
Location: First one out of liberty city, burn it to the ground
Man whoever you guys are looking at buying those v6 rockers from are smoking crack, i bought my 1.6's for 115.
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yup, in jegs, 1.6 for the 2.8 IS $119.00, 1.5 is $109.00.
now if it were the full roller rockers for the sbc that fit for $150. schweeeeeeet!!!!
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived,
working on getting some 3.4 heads.
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived,
dam I went to jegs awhile ago and they wanted 159 for em! Crap. Oh well I guess I know now... Lol
No wait, found them......
http://www.jegs.com/cgi-bin/ncommerc...031&prmenbr=76
$ 135.99
I did save cash!
$ 135.99
I did save cash!
<font face="Verdana, Arial" size="2">Originally posted by Xenodrgn:
</font>
</font>
Car: 1995 Z28
Transmission: Built 4L60E
I was wondering how bably does 1.6 rockers screw up the Computer? and if so can it be altered without a chip?
I had NO tap at all even 6000 rpm +....
Car: 1986 Firebird
Engine: 2.8 V6
<font face="Verdana, Arial" size="2">Originally posted by 614Streets:
that I could do something to my truck and cure my boredom. So I thought I'll try to place my Small Block Chevy V8 1.6 Rocker Arms on my 2.8 liter V6. I have a V6 Performance book that clearly states that any narrow enough rocker arm from a small block chevy v8 can be used on a 2.8 Iron head. What would not work was a arm with 3/8 or 7/16 stud , because the 2.8 head has a 10mm stud. However I found that on my 1.6 stamped roller tip rocker arms for the sbc could be used if I just reused the pivot washer and the old stud nuts. So I did it, it worked and I am happy with the Increased power.</font>
Is there a company out there that makes a rocker ratio between 1.52 and 1.6 for a SBC? I always thought a 1.55 would be a good idea... I'd probably go with 1.52's because of the "new" emissions test in NJ, but I might be persuaded to go up to 1.55's...
-Tom P (Hot rodded 1986 Firebird 2.8l)
<font face="Verdana, Arial" size="2">Originally posted by TomP:
Thanks for the info, 614! I was wondering about that a while ago ( https://www.thirdgen.org/messgboard/...ML/000144.html ), glad to know it -does- work. What do you think they meant by "narrow enough"? Narrow enough, as in, so the intake rocker and exhaust rocker didn't bang into one another?
</font>
</font>
Thats is a good question about the off 1.55 rockers. I bet if they exist then they are available for the sbc. Then you can have your cake and eat it too Tom!
-Will
Oh also forgot, anyone who wanted to use 1.6 ratio arms on the extrme budget could use crane cams sbc part # 270-11802-16 . These are the stamped steel plain janes but hey, 1.6 for $80.99
Damon
09-26-2015 04:29 PM
