Perma cool 2950 & 1650 CFM 16" & 12"elec. rad fans
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
I have a pair of electric Perma Cool fans. Used, but in very good condition. (less than a year, and less than 5000K mi old).
Part numbers is PRM-19115 for the 16" lightweight aluminum blade one
Help keep your radiator from getting all steamed up with one of Perma-Cool's High Performance electric fans. They feature high-rpm, pancake-style electric motors with long-life ball-bearing armatures, open steel housings for unrestricted airflow, and six silver-anodized aluminum blades with an aluminum center hub. These fans are reversible, for front or rear mounting, and can move up to 2,950 cfm of air to cool your radiator.
Specs
Fan Diameter (in): 16.000 in.
Height (in): 16.000 in.
Width (in): 16.000 in.
Thickness (in): 3.750 in.
Maximum Fan CFM: 2,950 cfm
Number of Blades: 6 blades
Maximum Fan RPM: 1,750 rpm
Blade Material: Aluminum
Blade Color: Natural
Amp Draw: 9.80 amps
Quantity: Sold individually.
Notes: This is a reversible fan that can be used as a pusher or a puller.
Summit price $112.95 First $35 plus shipping takes it.
Part number for the 12" with nylon blades is PRM-19008
Specs
Fan Diameter (in): 12.000 in.
Height (in): 12.500 in.
Width (in): 12.500 in.
Maximum Fan CFM: 1,650 cfm
Number of Blades: 10 blades
Maximum Fan RPM: 2,400 rpm
Blade Material: Plastic
Blade Color: Black
Shroud Color: Black
Shroud Material: Plastic
Amp Draw: 7.50 amps
Summit price $95.95 First $25 plus shipping takes it.
All they need is the nylon tie mounting kit from summitracing that is $6.95 each set.
I can take pics of the fans and send them on request. Best reasonable offer will take the fans.
Specs
Amp Draw: 9.80 amps
Specs
Blade Color: Black
Shroud Color: Black
Amp Draw: 7.50 amps
Car: 1988 IROC-Z
Engine: 383 HSR
Axle/Gears: 4:10
Re: Perma cool 2950 & 1650 CFM 16" & 12"elec. rad fans
Get ready for summer heat. How does 25 and 35 bucks sound plus shipping?
Dragonsys
09-25-2015 03:51 PM
