91 Z28 L98 350 with 121K Longblock in GA.
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Due to a fellow member really needing the wiring harness out of this car, I'm parting out this engine. This engine ran great with no noise, I did shot a video of it running before I removed it 2 days ago. When cold it would smoke alittle at startup (Valve seals) and oil pressure was at 60psi and would drop to 35-40 psi after warmed up. This is from valve covers to oil pan, flywheel to harmonic balancer and stock exhaust manifold to stock exhaust manifold. This is a southern car and the engine isn't all rusty and passed Georgia emissions last year. The car was rear ended and has been off the road for about 6 months.
$350 with the oil cooler. $300.00 without the oil cooler.
Local pickup only.
Local pickup only.
Car: 91 Formula
Re: 91 Z28 L98 350 with 121K Longblock in GA.
Sale pending. To be paid for and picked up this Tuesday evening.
