Romac balancer for SBC SFI approved
Old 01-21-2008, 10:44 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
I used this for 2 seasons, about 8000 miles. It is a 6.200" (they call it a 7" balancer for some reason) neutral balance unit for 350s and any other internally balanced motors. You can use it on a 383 or 400 if it is set up for internal balance.
It's SFI approved and a lot stronger than stock. I had two stock 8 inchers crack and one fell right off the crank. These are rather expensive new. I paid $225 for this one. It's worth the money to know that won't happen again. It's also a lot lighter than any 8 inch balancer.
It looks brand new as you can see from the pictures.
Those marks near the center bore are supposed to be there. I did not do that myself. They give a little bit more of a press fit to make sure it stays put.
$150 plus shipping. I also have a billet timing pointer for this. $20
Old 01-24-2008, 12:21 PM
Car: 1971 Corvette
Axle/Gears: 3.36
Re: Romac balancer for SBC SFI approved
back up.
Old 01-30-2008, 03:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
pm sent
Old 01-30-2008, 03:44 PM
Car: 1971 Corvette
Axle/Gears: 3.36
Sold-both for $175 shipped
gixxer92
05-18-2017 11:20 AM
darwinprice
17
10-11-2015 11:51 PM
92rsvortec350
19
10-09-2015 09:39 AM
Bradsaundry
10-07-2015 04:35 PM
monte87cortez
09-26-2015 08:10 PM
Quick Reply: Romac balancer for SBC SFI approved
