1986 LB9 TPI 305 long block and lower intake - $100
1986 LB9 TI 305 long block assembly. The engine will need to be rebuilt. It has a loud rattle in the upper end of the engine. I think it may have a collapsed piston skirt. It still ran smooth so whatever the problem is its still firing on all 8 cylinders. Oil pressure was 25-30 PSI at idle and operating temp. Block part #408855, date code E076(May 7th, 1986) Head part # 14014416, date code E086(May 8th, 1986) Block is cast for flat tappet lifters and one-peice rear main seal. $50. Local Pickup Only.
1985-86 TPI lower intake for perimeter bolt heads and 90 degree center intake bolts off the same engine. Part #14081005. $50 shipped in the lower 48 states.
Parts are located in the Madison, WI area.
Re: 1986 LB9 TPI 305 long block and lower intake - $100
Anything wrong with the intake? Any bolt holes stripped or anything? Does the $50 include shipping? Is that the lowest you can go? My zip is 35653. Thanks.
Fast355
12-02-2016 06:33 PM
1992rs/ss
16
01-28-2016 09:58 PM
