For Sale! Mickey Thompson ET Drag Wheels! Hoosier slicks!
i'm selling as a package deal, all four wheels, all four tires, and the two center caps. lug nuts included...i have enough 20 12x1.5mm and 10 1/2x20 for those running stouter rear studs.
the wheels are:
15x3.5 with 1.75" backspacing wrapped in 26x7.5 mickey thompson sportsman front runners with about half the tread life left. these wheels weigh in at 8lbs without tires!
15x8 with 4.5" backspacing wrapped in 29x9 hoosier drag slick made with the DO6 compound...very sticky! these wheels weight in at 10lbs without tires! the tires have ~half a season on them!
VERY lightweight wheel/tire combo!
These wheels retail for ~$280/each in the summit catalog, and the 15x8 is no longer available in the 4.5" backspacing so they're not easy to get anymore. my wheels are in near perfect condition with a few light scratches from accidentally dropping lugnuts while installing. the rears have been drilled for rim screws and are all perfectly spaced (i used the rim screw template), with 16 screws on each side. these are ready to make your 60's drop!!!
$950 OBO
the wheels are:
$950 OBO
Re: For Sale! Mickey Thompson ET Drag Wheels! Hoosier slicks!
they are 14 1/4" inner diameter. here's a picture of the backside, you can see that the wheel is all one piece and the inner diameter goes all the way down to the inner face of the wheel where it makes a sharp turn inwards...so i'm certain they'll fit over ls1 brakes
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I love that set of wheels. If I had more money I would go for them. Pretty soon I will burn through my set of street radials at the track and go for a set of these. BUMP for a nice set
this is a steal of a deal. 29x9 hoosier slicks (DO6 compound) on a 15x8 wheel w/ 4.5" BS with rim screws evenly spaced using a template, 16 on each side. these weigh 33.6lbs each WITH a fully inflated tire! it don't get any lighter than this! NO curb rash. $500 OBO picked up, or will ship for actual shipping cost. i will have to break these down to ship though to insure they get there safely.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
This is a great deal for anyone. Spend the money now and get the fronts later. Wish I had the money!
bump, this is a good price, and i'm willing to SHIP! i found a source for boxes that will actually fit these without breaking them down. and they're good solid boxes to boot! i'll do $600 shipped anywhere in the lower 48!
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
I noticed someone earlier in the thread that if the back spacing was correct he would buy these. will these not fit on a un-modified 3rd gen?
sean has a fourthgen rearend and requires more backspacing since the rearend is wider. these wheels will fit a stock thirdgen width rear without any problems whatsoever. the tires are taller than what normally are run and you will have to do a little "massaging" to get it to fit without rubbing. if you went with a shorter tire, you wouldn't have to do anything.
bump bump bump! if these don't sell soon, i'll break them down and sell the wheels on ebay...i gotta guy intersted in the tires out in california, but nothing on the wheels...NO REASONABLE OFFER REFUSED!
colton_carlson
03-08-2019 12:21 PM
Beeman
08-31-2015 07:40 PM
