[TX] Differential mounted VSS for LS1/(TH350;700R4;other) swap
Car: 1987 GTA
Transmission: 4L60e
Originally purchased from Jags that Run and used for maybe 1/8 mile before I decided to use a 4L60e instead. The bracket and attaching bolts were modified for fitment on a 9 bolt, drilling will be required on your diff for this kit to mount. The kit includes:
$75 shipped within the 48 continental United States.
- VSS sensor
- VSS bracket (2 additional holes, some trimming for better fitment, and light oxidation)
- VSS sensor connector + several feet of wire inside loom
- 2 halves to 40 tooth ring
- 4 bolts to attach ring (we shortened these and rounded the ends for better fitment, you might just replace them)
- 2 bolts for attaching vss bracket
- 1 nut for above bolts (lost the other - not a hard find at any fastener store)
700r4, bolting, bracket, conversion, differential, differentialmounted, jags, kit, ls1, mounted, run, swap, th350, tpi, vss
