[NC] LS1 swap harness
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
LS1 swap harness
This one has been sitting around too long. Swap harness for a LSx engine (4.8/5.3/5.7/6.0) in Fbody dress to a 90-92 3rd gen
Options and specifics
Year of 3rd gen:
90-92
Original trans type:
Auto
Year of PCM:
99-02
PCM location:
Stock 3rd gen
PCM routing:
Hidden under HVAC box (requires 2" hole cut)
Trans type:
4L60E
Block type:
GEN III LS1, LS6, 99-06 4.8/5.3/6.0
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6
MAF type:
Truck 5 wire
MAF location:
Near fender
AC:
Delete
Emissions:
Delete
Rear O2s:
Delete
Coolant gauge:
98 Fbody CTS in driver cyl head
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Digital cruise control:
Yes
Number of fans:
Dual
Battery location:
Pass side
Relay center location:
Hidden under battery tray
I built this for a friend using my core harnesses. He never went through with the swap so Ive got this laying around. Layout is identical to my swap
$520 shipped
Add $150 for a 0411 PCM tuned for a 5.3/4L60E with everything above accounted for (VATS, emissions, O2s, AC idle up etc)
Looks like this installed
Year of 3rd gen:
90-92
Auto
Year of PCM:
99-02
PCM location:
Stock 3rd gen
PCM routing:
Trans type:
4L60E
Block type:
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6
MAF type:
Truck 5 wire
MAF location:
Near fender
AC:
Delete
Emissions:
Delete
Rear O2s:
Delete
Coolant gauge:
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Yes
Number of fans:
Dual
Battery location:
Pass side
$520 shipped
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: LS1 swap harness
Can you make one for a 92 Z28 LS3 with a 4l80e? How does it interact with the cluster?
allen.bray64@yahoo.com would you need my motor or dash harness?
Car: 1991 Z28
Engine: 6.0, forged internals, 243, EPS cam
Very interested if you can add A/C. I have a 91 Z28 with all the specs mentioned above. What is the MAF truck 5 wire? And what else would I need to make it work with my gauges, speedo and engine light?
Car: 92 25th anniv. camaro
Engine: ls-6 V8
Transmission: t-56 6 speed
Axle/Gears: 3:73
hello i live in raeford, NC just outside of Fayetteville, nc can you build me a harness for my ls6 swap in my 92 camaro? If so how much will you cost me to do the work. if you are close i will help on the work also. my email is nealey822000@yahoo.com.
V/R
Mike
US ARMY
V/R
Mike
US ARMY
Engine: Cammed 6.0L LSX
Jon's harnesses are the way to go. I've bought two of them from him and couldn't be happier. Bump for an awesome guy/wiring genius.
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
I will be sending him mine soon, for my ls1-t56 swap.
