Parting 82 Z 43000 miles 305 cfi
I will be parting this car in the next week https://www.thirdgen.org/forums/hist...-1982-z28.html.
The Motor runs great and the trans shifted perfectly. I am located in Racine county in WI. Let me know if there are any parts you are looking for, Thanks.
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Parting 82 Z 43000 miles 305 cfi
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
I would be most interested in the fuel lines to/from the TBIs on the engine. Is the intake line complete from the fuel filter connection up? Only the top portion is visible in the picture.
I might be interested in the entire CFI set up from the intake manifold up if your are interested in just selling that.
PM me and we can discuss.
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I need the cruise control transducer. Is it in functioning condition? Got a picture of it, and how much would you want for it?
Thanks!
Thanks!
Josh
The rubber hose on both the return line and the intake to the fuel filter were stock. I think these fuel lines were installed on the engine prior to the engine being installed in the car. The rubber lines were then attached to both ends of the hard lines. The rubber lines just gave them a bit of slop at the connection points to the hard lines that was easy to install.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
How much for the gauge cluster and steering wheel (w/horn button)?
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Center console lid assembly if it opens sideways.
Seatbelt guides?
Rear ashtray?
BTW, that speedo gauge is awesome.
Seatbelt guides?
Rear ashtray?
colton_carlson
03-08-2019 12:21 PM
1992 Trans Am
08-08-2015 08:16 PM
3rdgenparts
08-06-2015 09:03 AM
