[For Sale] LS1 swap harness
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
LS1 swap harness
This one has been sitting around too long. Swap harness for a LSx engine (4.8/5.3/5.7/6.0) in Fbody dress to a 90-92 3rd gen
Options and specifics
Year of 3rd gen:
90-92
Original trans type:
Auto
Year of PCM:
99-02
PCM location:
Stock 3rd gen
PCM routing:
Hidden under HVAC box (requires 2" hole cut)
Trans type:
4L60E
Block type:
GEN III LS1, LS6, 99-06 4.8/5.3/6.0
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6
MAF type:
Truck 5 wire
MAF location:
Near fender
AC:
Delete
Emissions:
Delete
Rear O2s:
Delete
Coolant gauge:
98 Fbody CTS in driver cyl head
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Digital cruise control:
Yes
Number of fans:
Dual
Battery location:
Pass side
Relay center location:
Hidden under battery tray
I built this for a friend using my core harnesses. He never went through with the swap so Ive got this laying around. Layout is identical to my swap
$520 shipped
Add $150 for a 0411 PCM tuned for a 5.3/4L60E with everything above accounted for (VATS, emissions, O2s, AC idle up etc)
Looks like this installed
Year of 3rd gen:
90-92
Auto
Year of PCM:
99-02
PCM location:
Stock 3rd gen
PCM routing:
Trans type:
4L60E
Block type:
Intake:
LS1/LS6 car style
Throttle Body:
Drive by cable
Injector style:
LS1/LS6
MAF type:
Truck 5 wire
MAF location:
Near fender
AC:
Delete
Emissions:
Delete
Rear O2s:
Delete
Coolant gauge:
Alt:
Fbody 1 wire
Alt Location:
Stock Fbody
Yes
Number of fans:
Dual
Battery location:
Pass side
$520 shipped
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: LS1 swap harness
Can you make one for a 92 Z28 LS3 with a 4l80e? How does it interact with the cluster?
allen.bray64@yahoo.com would you need my motor or dash harness?
Car: 1991 Z28
Engine: 6.0, forged internals, 243, EPS cam
Very interested if you can add A/C. I have a 91 Z28 with all the specs mentioned above. What is the MAF truck 5 wire? And what else would I need to make it work with my gauges, speedo and engine light?
Car: 92 25th anniv. camaro
Engine: ls-6 V8
Transmission: t-56 6 speed
Axle/Gears: 3:73
hello i live in raeford, NC just outside of Fayetteville, nc can you build me a harness for my ls6 swap in my 92 camaro? If so how much will you cost me to do the work. if you are close i will help on the work also. my email is nealey822000@yahoo.com.
V/R
Mike
US ARMY
V/R
Mike
US ARMY
Engine: Cammed 6.0L LSX
Jon's harnesses are the way to go. I've bought two of them from him and couldn't be happier. Bump for an awesome guy/wiring genius.
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
I will be sending him mine soon, for my ls1-t56 swap.
Car: 89 Camaro-RS
Engine: 305ci
Axle/Gears: 10 bolt posi
As soon as my swap is ready I'll be calling him.I here he's the best.
Car: 85 trans am
Engine: ls1
Transmission: t-56
Hey. Im putting in a ls1 with t-56 trans. in my 85 trans am. Im also putting in a 4th gen dash and cluster in it. How much would you charge to make the harness for me?
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
sorry for the dumb question how do you pm...............??????????
Engine: ls1
Transmission: 4l60e
barley takin the engine out of a 99 camaro........... next step is motor mount and crossmember for the third gen... then the harness just need a heads up on the wiring harness price to get ready.....
Car: 92 Firebird
To PM, you click on the user's screen name and wait for the drop down menu to pop up. Click send a private message to "xxx". Type your msg and send
To access current and prev messages, click on user control panel at the top of the page. Its got alot of cool features you'll want to play with
