dual 16" electric cooling fans, and dual 12" electric cooling fans
I got 2 brand new 16" S-blade cooling fans, they are procomp electric fans as well as two 12" S-blade cooling fans. One 16" fan has maybe 20min run time on it and so does one of the 12" fans. Didnt have enough room for dual 16" fans on my setup and i'm going another route.
heres the specs for 12" fans
CFM
Pull-1200-1450
Push 1350-1550
Dimensions
11 x 12 1/2 x 2 1/2
Amps
5.5
Volts
Pull-1200-1450
Push 1350-1550
Dimensions
11 x 12 1/2 x 2 1/2
Amps
5.5
Volts
Heres the specs for the 16" fans
CFM
Pull-2400-2700
Push 2200-2500
Dimensions
16" x 16.9" x 3.2"
Amps
7.5-8.5
Volts
CFM
Pull-2400-2700
Push 2200-2500
Dimensions
16" x 16.9" x 3.2"
Amps
7.5-8.5
Volts
I still have the boxes for the 16" fans as well as the mounting tabs. Im willing to throw in a set of cooling fan mounting kits from Derale for an extra 5$ for BOTH! I onl have 2 sets so first come first serve with the mounting kits. http://www.summitracing.com/parts/DER-13001/
Selling the fans as pairs, do not want to split up the fans as a pair. Im willing to ship to continental USA 48 states. And price does not include shipping.
two 16" fans= 50$
two 12" fans= 35$
mounting kits for 2 fans=5$ with fan purchase.
Shipping is not included and will be calculated when Zipcode/state is provided. I accept money order, personal check, and paypal.
two 16" fans= 50$
two 12" fans= 35$
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: dual 16" electric cooling fans, and dual 12" electric cooling fans
pm sent
Car: 1966 El Camino Custom
Transmission: 200R4
Can you send pics of the 12" fans to maggieandbill@comcast.net
One 12" fan has about 20 minutes. How much time on the other?
I will try to send the pics tmrw... as i am not home to take a picture of them.
The other fan was never used... i only used one of the 12" fans and 16" fans and realized it i wanted to go another route.
I had a 16" and 12" fan on my 31"x19" radiator and had them running for about 20min then i realized that I wanted to get a shroud setup. Which i did and im keeping that setup and it works the best in my application.
I had the two 12" fans setup on my rad originally before turning them on and was told i needed more CFM (im running a 521cuin BBF in my 87 bird so i need lots of air). This is what the 12" fan looks like. These things look brand new as they were never actually run on the street. http://www.store.procompelectronics....oduct_id=36840
if you still want the pics let me know, and ill snap a few on my cell tmrw.
Transmission: 200R4
I'll take the two twelves. I'm at 87108. PM me the total cost and how you want to be paid.
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
