[Sold] FS: PBR/LT1 Rear Disc Brake Swap
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Tim in Wyoming 82601
Maybe it's time to replace your old worn out drum brakes in your 10 bolt or 9 bolt rear with 11.6" disc brakes.
I have two perfect PBR/LT1 style rear calipers with lines, hardware, and two professionally inspected and turned rotors from a 97 Camaro Z28. All you would need are the mounting brackets and proportioning valve from flynbye performance to turn your third gen drum rear into a disc-braked rear.
The rotors are the same bolt pattern as a third gen's bolt pattern and will bolt right on.
These calipers cost $275 each at flynbye performance.
PayPal is timmytina350@msn.com
$315.00 shipped for all you see in picture (except my foot he he he).
$399.00 shipped with the brand new swap/mounting brackets
Car: 1995 Formula
Engine: LT1 350
Re: FS: PBR Rear Disc Brake Swap Setup
bump--keep in mind that these calipers are $275 each if new from flynbye performance.
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Do these connect to a parking brake cable? Or do they require parking shoes?
Thanks,
Jon
Thanks,
Jon
Car: 1995 Formula
Engine: LT1 350
Correct. You need the swap e brake cables from Hawks or FlyNbye performance and they connect to the caliper e brake hookups that are on the calipers and then they hook to the e brake cable already on the car.
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
novaderrik
08-10-2015 12:44 PM
1992 Trans Am
08-08-2015 08:16 PM
