[Sold] Mcleod adjustable master cylinder
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
<<< SOLD >>>
Was used in a 3rd gen LS1 swap for less than 2K miles before changing to TH400 and turbos.
$200
$200
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Mcleod adjustable master cylinder
Bump.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
If you expect to do quick shifts at high RPM with a T56 then you'll need something like this. Also needed for extra fluid volume when you upgrade clutches.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Bump.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You can't get a performance master cylinder for a 3rd gen. You have to adapt a 4th gen piece. This requires you to change the connection at the clutch pedal, or swap out to 4th gen pedals. This moves more fluid so you can run a more aggressive clutch and makes it possible to shift faster.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
did you ever have any problems with it? the one i got was rebuilt from mcleod, so hopefully it's good to go
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I never used it. This was going in my car but I changed my mind. The history of part is from LS1>* who is a member here. It worked good for him and he has 30 positive feedbacks so I wasn't worried. Nevertheless, one must understand that when buying a used part you take a risk. If you want zero risk then you pay the big bucks for new.
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
If anybody decides to pick this unit up and wants to rebuild it, contact CNC brakes in
San Diego 619 275 1663 and pick up rebuild kit p/n 910ML. It will be good as new.
CNC was the company that made the masters for McLeod, but now that Mcleod is having them made by wilwood they dont sell rebuild kits any longer.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It shouldn't need a rebuild. I don't want people to think they need to factor in that cost.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yes, as long as you still have a shipping address in the US.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Sold.
codeysabatini
11-10-2015 04:07 PM
camaro1185
10-26-2015 06:51 AM
topteam54
10-06-2015 12:21 AM
