[MD] Custom Y-pipe and crossmember for longtubes and T5 - SOLD
This Y-pipe fits cars with a T5 and Hooker 2210 or Doug's longtube headers. I also have a custom made double-hump trans crossmember that was made from a factory x-member. This y-pipe had great ground clearance even on my lowered car.
$150 for both the Y-pipe and crossmember.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Custom Y-pipe and crossmember for longtubes and T5
Any pix of the setup in the car showing ground clearance?
-- Joe
To be honest, I have no idea how the cross member was made. I bought it from another member on here about a year ago. It's definitely a cool setup and it fit great. The only reason I'm selling is because the T5 is gone and I have a T56 now.
And unfortunately I never took a picture of it in the car. But very rarely did I run into any ground clearance issues, and my car is lowered 1.5" The headers will scrape before the y-pipe will. It tucks up very nice.
-- Joe
I've got pretty much the same y-pipe setup, but mine goes under the cross member which is stupid. I was going to cut and redo everything, but if the price is right to my door it will save me a few hours of cutting and welding.
-- Joe
Re: Custom Y-pipe and crossmember for longtubes and T5 - SOLD
Arrived today. Interesting packing skills
Thanks!
-- Joe
Thanks!
-- Joe
What style trans mount did you use?
Just got around to trying this. The two bolts on the trans mount hit the flat part of the cross member. i see in the pix it hit on yours two, but on mine I have a good 1/2" or more before the bottom of the mount seats.
I don't care - mind you, I'll probably just take the torch to it and blow two holes to clear the bolt. But I'm curious what you used for a mount.
I really hope these 2210 long tubes fit with my scattershield. I can barely fit my fist between it and the frame, I don't know how the heck the collector is fitting their..
-- Joe
-- Joe
Street Lethal
04-30-2019 12:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-22-2015 08:28 PM
