Gears Axles 10 Bolt stuff
Gears
2.73 Gear Set $50 + shipping
3.23 Gear Set $70 + shipping
3.42 Gear Set $80 + shipping
3.73 Gear Set $80 + shipping
Axles
82-89 26 Spline Axles $50 + Shipping
90-92 28 Spline Axles $90 + Shipping
4th Gen 28 Spline Axles $80 + Shipping
Aslo got some small parts too:
10 Bolt Ring Gear Bolts $10 + Shipping
Pinoin Gear Shaft and locking bolt $20 + Shipping
Send a PM that includes your ZIP code for a shipping quote if you need any of these parts.
Axles
Car: 1986 Camaro
Engine: 355 tpi
Re: Gears Axles 10 Bolt stuff
Alright I need the 28 spline for the 90-92 and the 3.73 gears. I just payed for a zexel torsen so I need some gears with it lol
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
i have a 95 rearend outta a formula in my 82z. its a 10 bolt 2.73 posi. would the 3.42 gears work?
using the parts you've got now..... Yes/NO.
It's possible, but only by using a "spacer". I have never used a spacer for the rear gear-set and would not recomend thier use.
Your well advised to use your existing rear end housing with a 3-series carrier that's made for 3-series gears. ( 3.23 to 4.11 gear )
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
hectre13
08-26-2015 08:17 AM
red90IROCls1
08-25-2015 06:56 AM
