[MD] COMP Cams valvetrain parts - roller lifters, pushrods, valve springs & retainers
Everything is brand new and still in the boxes. I'll cover the shipping and I accept PayPal.
850-16 Hydraulic roller lifters $170 SOLD!
7808-16 pushrods 5/16" diameter, 7.195" length, heat-treated steel, welded ball tips $25
26986-16 Beehive Valve springs $170 SOLD!
•1.415" OD
•1.000" ID
•1.060" Coil Bind Height
•280 lbs./in. Spring Rate
•Seat Load: 123 lbs. @ 1.750
•Open: 284 lbs @1.175
•Not coated
•O.D. at top of spring is 1.065 in. and I.D. at top is 0.650 in.
787-16 Steel Valve spring retainers 7 Degree lock style and are designed to be used with the above valve springs $40 SOLD!
•1.415" OD
•1.000" ID
•Not coated
Car: 87 Chevy Camaro
Engine: 305 V8
Transmission: 5 Speed Manual
Re: COMP Cams valvetrain parts - roller lifters, pushrods, valve springs & retainers
Not to sound absolutely cheap as hell lol, but whats the cheapest you would go for the roller lifters and push rods together shipped?
1988iroc350tpi
08-14-2015 07:52 PM
