[NC] 3.42 posi disk axles
Old 05-31-2014, 01:45 PM
Pocket's Avatar
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
I have two 3.42 posi 10 bolt rear ends with LS1 disk brakes, ready to bolt in One left
$250 each
$50 less if you dont want the brakes
Prefer not to ship the axles
LS1 alum driveshaft with damper Sold
Mocksville NC
Parting out a 2000 Z28 if you need anything
Old 05-31-2014, 03:05 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: 3.42 posi disk axles
Are these 4th gen axles?
Old 05-31-2014, 05:10 PM
badtenant's Avatar
Car: 92 RS
Engine: No Engine at the moment!
Transmission: TKX - On the transmission stand!
PM sent...
Old 05-31-2014, 06:26 PM
irocbrninrubber's Avatar
Do you have the dash pad? if so, how much for it?
Old 05-31-2014, 08:04 PM
Pocket's Avatar
Car: 92 Firebird
Yes, 00 and 02
Dash pad is busted
Old 06-07-2014, 08:25 PM
JTV
JTV's Avatar
Car: 1987 Pontiac Firebird
Engine: stock LG4 305 ccc
Transmission: r700
Axle/Gears: 2.73 (turd)
are the 10 bolt rears out of 3rd gen?
Old 06-08-2014, 11:09 AM
Pocket's Avatar
Car: 92 Firebird
4th gen as stated in the previous post
Old 06-08-2014, 12:20 PM
JTV
JTV's Avatar
Transmission: r700
PM sent. very interested. I'm in Richmond, Va .
Old 06-10-2014, 11:34 AM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
Mileage any upgrades?
Old 06-10-2014, 02:39 PM
Pocket's Avatar
Car: 92 Firebird
137k and unknown
Stock
No known issues with either
Old 06-10-2014, 03:00 PM
RamIt's Avatar
Car: 1984 z28
Engine: 93 LT1 350
Axle/Gears: 7.625" 28 spline 3.23
Guys, this is a very good deal in my neck of the woods for a 3.42 axle with torsen and 28 spline axles. I would ****** them both if you were closer.
Old 06-15-2014, 05:08 PM
Pocket's Avatar
Car: 92 Firebird
Bump, both buyers backed out last minute
Old 06-16-2014, 02:59 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
You say prefer not to ship, since buyers backed out and if you don't have any luck locally would you change your mind? I am in Aliquippa, PA ZIP 15001. Interest in how much it would cost to ship
Old 06-16-2014, 06:08 PM
Pocket's Avatar
Car: 92 Firebird
Likely in the $150-200 range single, $2-300 both
Old 06-25-2014, 08:02 AM
Pocket's Avatar
Car: 92 Firebird
Last bump before I throw them on ebay
Old 06-25-2014, 07:03 PM
Chevy2035's Avatar
Car: 92 Camaro RS
Engine: 355, Vortec heads, XE274 cam, 9.8-1
Transmission: 700r4 built for 800-900hp
Axle/Gears: 3.73 Gov Lock, Soon to change
They include Prop valve?
About how far are you from Jacksonville NC?
Old 06-25-2014, 07:34 PM
Car: 88 Iroc Z
Engine: L98 350
I'm currently running a 3.42 out of an 95 trans am is the breaks or anything hooked up different from a lt1 to an Ls1
Old 06-26-2014, 06:12 AM
Pocket's Avatar
Car: 92 Firebird
No, these are strait out of a 4th gen
Jacksonville is about 4 hr from winston
Different cables. The chassis to axle line is the same
Old 06-26-2014, 07:39 AM
Car: 88 Iroc Z
Engine: L98 350
Is the ls1 rear brakes bigger than the Lt1s? Is the parking brake cable just different from the caliber and use the same connection at the center hookup or is it a conversion to make it work? And will the hydraulic break lines an easy connection if I'm not mistaken wont nontraction controlled lines hook up to ours?
Old 06-26-2014, 03:26 PM
cougar68's Avatar
Car: 1992 Z28
Engine: 5.7L LS6
Did you get my PM I'm going to buy one
Old 07-03-2014, 09:53 PM
Pocket's Avatar
Car: 92 Firebird
Sold one to cougar
Galaxie500XL
10-01-2015 01:05 PM
JSDaddy189
09-26-2015 03:50 PM
Quick Reply: [NC] 3.42 posi disk axles
