91 GTA AIR DEFLETOR
Car: 91 TRANS AM GTA WS6
Transmission: T5 5speed
91 GTA AIR DEFLETOR
Hi Guys, I need the lower air dam for a 91 GTA all 3 pieces(with mounting bolts if possible). I know it's a long shot but I also need the front ground effects. All I have under there is the core support and front bumper, everything else is gone. Let me know what you have.
Re: 91 GTA AIR DEFLETOR
Just so you know, it's technically 4 pieces. The radiator air damn is made up of 2.
Good luck.
I bought the drivers side air damn for the gfx from here:
http://www.ebay.com/itm/111356537617
Good luck.
Well, I hope I have some luck anyway. I found one from a standard firebird that will keep the car from overheating, but definitely not correct.
Just scored this off of E-Bay. Hope it's correct for the car...
http://www.ebay.com/itm/331127668592
If you ever find an original though in really good condition tho you should buy it, the original one, the portion that is the lower part, was originally softer than the later made ones even though they are the same part number.
Cool, glad it's the right part. Anybody got a pic of what it's supposed to look like under ther? I got nothing there so just trying to get an idea.
Want a title? Post!
Car: 1992 Firebird Base
Engine: LH0 3.1L V6 191 CI
Transmission: TH700-R4 4-Speed Automatic
Axle/Gears: Stock
I'm also in need of a complete air dam for my 92 firebird base if anyone can help.
Stupid phone problems, **** I'm pissed...
Anyway, yeah paint the smaller front piece to body color, then drill the larger rear piece for those 2 mounting posts to come thru. GM used these little press on metal lock washer/nut type looking things originally that just slipped over the posts and would not easily pull back off.
Want a title? Post!
Axle/Gears: Stock
Here's the link to my thread about fixing up the car. I'll put up a picture of the "New" Air Dam installed when I get it on there.
https://www.thirdgen.org/forums/memb...-firebird.html
Last edited by powderedwater67; 07-16-2014 at 02:37 PM. Reason: Added missing info
So still looking for the outside air deflector's left and right if anyone has them.
The_Phoenix
02-04-2016 07:10 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
08-24-2015 06:52 AM
