Griffin or Be Cool radiatior?
Which do you guys think is the better one based upon cooling the best. Also what modifications had to be done to install either one? Thanks a bunch.
Graham
Graham
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
There are actually 2 different Griffin models for our cars: one with 2 rows of 1" tubes, one with 2 rows of 1-1/4" tubes. I couldn't fit the bigger one in my IROC, but the smaller one (heheh, it's still HUGE! ) does fit w/out any serious modifictaions. All I had to do was put some spacers between the fan mounts and the supports and modify the top cover some to fit over the radiator and A/C condenser.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Engine: 385 HSR
The Griffin rad with dual 1" tubes and an internal cooler (for tranny fluid) is model # 6-282AE-BAX. I got mine for a little over $300, but that place wasn't able to sell enough radiators to continue being a distributor for them. The actual manufacturer's cost is a little under $300, so how much is costs depends on how much mark-up is being charged.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: 88 Firebird WS6
The 31x19 dual 1" core from summit GRI-1-25272-X and costs $181.95
The 31x19 dial 1 1/4" is GRI-1-55272-X and costs $281.95
Plus if the 10% off offer is still good it will be cheaper...
Engine: 385 HSR
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
</font>
</font>
Greg Westphal
'87 IROC 305TPI/A4
THe Griffin one requires modification to the fram rails if you get the "direct replacement" one that is made for our cars.
</font>
</font>
91 RS/3.1 - Stock except stereo system, daily driver.
86 IROC - T-Tops, 350/TH350 w/shift kit, 2600 Stall, 3.42 geared 12 bolt, Performer 750cfm, Performer RPM, Comp Cams 280 magnum, Hooker 1 5/8" shorties, Flowmaster Y pipe, 3" to Flowmaster 2 chamber Dual outlet.
OK, sorry about the confusion, but he mentioned the griffen nascar radiator was not a 'direct replacement' in a prev post.
First thing is if you have a small hose attaching to the radiator from the heater. You will need to run this into the bottom hose somehow. I had a friend weld a 3/4" pipe into a larger (forget the size) pipe and just spliced it into the hose.
I removed the rubber bumpers from the frame and put a thin rubber (tube) in the bottom. I couldn't re-use the upper support and since the tops of the electric fans mount there I had to make brakets for them, and a way to mount the radiator. I had to cut some material off the upper support area, and since the hood wouldn't shut with my first design upper support (that went over the radiator like stock) I just drilled 1/8" holes in the top of the flange and bolted it into the flange on the radiator with self tapping screws.
If you don't have access to do this kind of stuff get the becool direct fit radiator. It will cost ALOT more though some people say the ease of installation more than makes it worth it. I did all the mods and had it mounted the first time to find the hood didn't shut and my 1st brakets were tossed and I started over and still got done in about 4 hours. I also had scrap material and all the tools and parts around. Bare minimum is a vise, some sheet metal, screws, and a air angle grinder with a cut off wheel.
Ohh.. you may not have the same kind of trouble I had because the camaros have more hood clearence in the front... You may get away with light mods to the stock support.
Hey Racer Let me know how your installation goes! I am curious to know what exactly you did to get it to fit. Did you get to NASCAR one with 1.00" tubes or 1.25" tubes?
If you don't have the smaller heater hose (some models didn't) it would be alot easier. If you don't have electric fans, easier yet, although you should keep you shroud if you have a clutch fan.
If i'm scaring you away, it's real, don't even open the box. Send it back.
For me though, the money saved on this big bass-add radiator compared to a direct fit was well worth it.
If you have an auto transmission, and aftermarket cooler will be required because there is no provisions for it. It's a good idea to have one anyway, but this requires cutting the lines and hosing it to the cooler mounted in front of the radiator.
The aluminum plate in the pic is where I cut material out and being the core comes up further than the sheetmetal, I made the plate to move airflow through it. It will look like hell if you leave it showing. At least that edge trim will dress it up. have no regrets about leaving the top of the rdiator exposed since it looks alot better IMO with all that aluminum saying... I'm not stock.
Cutting the framerails sounds quite severe though. The lower x-member I didn't modify except for removing the snap-in rubber gizmos.
Again this is a firebird so I had to tip the radiator back for hood clearence. Although I imagine now about thinking about it that for a camaro with the dual snorkel intake it still may pose a prob.
Don't open the box if you are afraid of tackling this job. I'm feeling guilty now, but if there's a will there's definatly a way! And considering the be-cools direct fit for an auto costs $541 from summit that just as well pays for aggrevation and a much better aftermarket tranny cooler.
And put it this way, I didn't know about this fitment prob until I tried getting it in there since I had no computer or internet at the time (But I'm a machinist, so working with metal and measurements is my life)
I guarantee you, if you get thst radiator in there you will NEVER have a cooling prob because of it. Actually my car cools too well and I had to up my thermostat to 170.
Thats the dual 1" not the 1 1/4...
I hope I gave you enough info to either tackle the proj, or scare you clear away. A excellent aluminum radiator for under $200 is the griffen. It will do just as well or better than the be-cool, but for the hassle, over $300 has been put back in your pocket.
Great info guys, thanks for taking the time to explain this.
gwman, I ordered the model # 6-282AE-BAX from Summit. It's dual 1" tubes with auto tranny cooler and is specifically intended for third gen f-bodys. It cost about $370.00 and I'll be happy to let you know how it goes.
Joel, thanks again man, I'm sure I can get it to fit, really, I'm a wiz with zip ties and pliers.
Joel thanks for the info. Mine is a 91 RS TBI so I have the heaterhose. How did you hook this up in yours since the Griffin doesn't have the connection on the radiator? Also, I have electric fans but they're aftermarket so they shouldn't be a problem, I'll just mount them through the core.
Engine: 385 HSR
<font face="Verdana, Arial" size="2">Originally posted by Scott_92RS:
So which one cools the best? Griffen or BeCool?</font>
Greg Westphal
'87 IROC 305TPI/A4
To add in the extra heater hose I took two pieces of heavy wall pipe
The big one (I can't rmember the size off hand) I cut about 5" long and the small one (3/4" OD) I cut 1 1/4".
Drilled a hole in the big pipe dead center and tig welded the small pipe in.
Then I just spliced this into the lower radiator hose and clamped it up.
Car: '91 Formula
Damn, I don't think I'd wanna put that much trouble into the radiator, and I don't think I'd want to modify the car that much away from stock. So I guess when I buy a new radiator, I'll pay the extra for a BeCool. Better start saving now I guess, unless I can find a cheaper vendor to sell it to me.
Hotrodboba400
12-10-2019 07:07 PM
