Which stall converter should I consider?
I really don't want to spend a fortune on a converter, but I do want one that isn't going to crap out on me and leave me having tranny problems. I saw one from summit that seemed pretty reasonable. It was the TCI staurday night special for the 700R4 with a stall speed around 2,000 and a 30-spline, 1.703 pilot for $265. It is my daily driver, so I don't need a very high stall. What are your thoughts on this one or advice on another one?
I plan on putting one on when I have the engine out. This will be the set up I will have: Edelbrock heads and high flow intake, LT4 hot cam, 1.6RR, and a few other things.
87'IROC-Z 350 TPI
Ported Plenum,Hypertech Air Foil,Ram Air kit,SLP headers,AFPR,80series flowmaster and MAF screens removed.
14.61@94mph(90+ degree weather)
[This message has been edited by southerniroc (edited October 16, 2000).]
87'IROC-Z 350 TPI
Precision Industries all the way, cant be it. Nothing else except nitrous or MAYBE high gears will give you 4-5 tenths and 1-2 tenths off your 60'. Plus with a P.I. you dont have to run a big gear which helps with gas mileage. I have many friends with LS1's and 3.23 gears with P.I.'s and they pull anywhere from 1.553-1.68 60'. WOW www.converter.com
I had gotten that same converter, TCI staurday night special, when I had my tranny rebuilt. My engine was still stock but it did make a difference. Unfortunately I never took it to the track so no times.
But then I put new heads (6085's) and a cam and RR and I think I would have liked a converter with a little higher stall say around 2500-2700.
My car is a daily driver and it has 2.77 gears in it. The tranny and converter are giong on 2 years and I've even took it to the track, see signature. I think the times would be better since I have a couple bad injectors. I think my 60' time was 2.05 or 2.03, not really sure, and no suspension mods yet.
If I was you I would try to get the VIGILANTE converter that "89ProchargerdROC" told you about. You will be much happier in the long run. It cost about 3x more but well worth it in the long run.
Good Luck!
89 IROC 350 Auto
TRUE DUAL Exhaust
Edelbrock Performer Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears
Good Luck!
89 IROC 350 Auto
TRUE DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
by the way the P.I engineering converter is 800$!!!!!. The holeshot 2400 with lockup is only 334 from summit and you can bet you'll fell that one......thats what Im going with
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
Car: 1987 Z28 Convertible
Transmission: 5-speed
It was a complete waste of $1000. If I had to do it all over again, Pro Torque is the way to go.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited October 17, 2000).]
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I have been running an SLP converter for years, and love it. I also have the Edelbrock heads and a mild cam. Check 'em out. I think the Vigilante is overrated, especially for a daily driver.
'87 IROC 5.7l TPI - original owner!
Willie,where can I get a stall like yours & how much are they?
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
I believe I paid $600. I know it's a bit on the pricy side, but I heard bad things (premature failure) about the "cheaper" units like TCI & B&M.
Willie
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
i paid 60 bucks for my 2800 non lck-up. and i paid 60 for my other one which had a 106K miles on it it was only a 2200 though, it lasted 2 yrs before i swapped it out when i put the 355 in and went with the 2800. the local converter shop modifies stock cases and builds race converters as well for about 500 i could've gotten a 10" 3000 stall, 2800 is the highest he could get with my stock 12", it works great but! my car suck on street tires, my stall is a little too high. hell istill get a little spin with slicks
87GTA looking for a super ram!!! 355, A4 ran high 12's with old school setup and radials, hoping for low 12's or better /91 TA daily driver LB9 A4 2.73,
Well, i know of a place by me that sells them for $700. Plus, so many people like them, it is easy to start a group purchase for them. Also, i think they really know what they are doing. Not flaming you willie, but when my friends can cut 1.55 with 3.23's in a LS1, that is impressive.
If you're tight for money, you could get stock replacements.
My 86 came with a B-type converter, which has a stall speed of 2400. It barely moves when you let off the brake and will actually roll back some on a hill. It bet it goes for $80 at most from a transmission parts retailer (DAACO/DETROIT).
My 89 came with the E-type, which is not as good (it's an RS, not a Z28 like the 86), and I think it's stall is 2000 or 2100. It'll pretty much run up to 30mph when you let off the brake. It's not as nice as the 86's TC.
As with any product, you'll see different people get different results. You'll see people swear by Fords (for example) and others who swear at them.
The reason why I decided to buy the Vigilante is because everyone had good things to say, never heard anyone with a bad experience. Unfortunately, I was the one. But I do have to give credit to PI for their absolutely awesome customer service. Normally, you get one "free" stall speed adjustment. Terry told me (at the time I had mine adjusted) that if it still doesn't work out, he will adjust it one more time at no cost. Needless to say, it will be shipped back for a second adjustment in the future.
Willie
Engine: 5.7l TPI
Axle/Gears: 3:23?
BTW, I seem to recall reading posts from Vader somewhere before in which he discussed various GM converters that were worth seriously considering. I think he referred to an S10 (yeah, the little pickup) converter that would fit the bill for most folks. It's relatively inexpensive and covered by warranty. Look it up.
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I love my Vigilante... Was well worth the money. I had the street fighter before, and I barely noticed any improvement over stock... But the Vigilante blows the Street Fighter away..
To give you an idea... I am running 1.88 60's while running a 14.1 in the quarter mile. (intake is my limiting factor right now) Before that I was in the high 1.9's 2.0's with the Street Fighter. And i get a lot more spin now and I do not have any aftermarket suspension components... I still have the 12 year old original bushings....
I know it sounds expensive, but they custom build them to your application and they are well worth the money.
The most expensive brand isn't always the best... But do a search on Vigilante or torqu convertors and see what you come up with. I bet Vigilante has the best satisfaction rate among us 3rd genners...
Hotrodboba400
12-10-2019 07:07 PM
MikkoV
09-09-2015 04:25 PM
