327 heads on 305?
Guest
Posts: n/a
327 heads on 305?
hi boys!. what about heads p/n 3890462 for my stock 305? my friend claims they are from a 327, close chambers, 1.9something valves,they will go with an aluminium performer intake and a 4barrel rochester m4mc carb.
so basically the questions are:
1-will it fit?
2-will increase power?
3-if it does should i use gas super?
thanks to all and keep kicking muswang morons butt!!!
1-will it fit?
I would venture to say they wouldn't, mainly cuz the 327 is a 4 inch bore engine, same as the 350. I do know that there are a set of 327 heads, maybe trick flows, that will work on the 3.73 bore of the 305, but I am again, not 100% sure.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
they'd bolt up. the big problem would be lowering your CR due to the larger size. the valve may hit the deck surface, if they don't good chance they'd still be shrouded and hurt flow.
-=ICON MOTORSPORTS=-
Guest
Posts: n/a
ok guys, sorry i wasn't clear, my 305 has open chambers and low comp. pistons (concave?)(the opposite to dome pistons) and the idea of a smaller chamber with larger valves does sound like more mass into...with higher compression (slightly).
basically biger valves and smaller chamber.
thanks for your oppinions.
fernando.
fernando.
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
