3 point Strut Tower Brace and Carb
I know that you can use the 3 point STBs for the tbi setup with a carb setup as well. My question is will the STB get in the way of my HEI distributor? I have the Hypertech cap and coil but I am thinking about switching to an MSD box w/ a separate coil.
am I going to have any problems with this?
Jay
Jay's Website
No car with 4 doors is a sports car! this goes back to my friend comparing his Maxima to a Camaro
Jay
Jay's Website
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
If you are referring to the Edelbrock brace,you will have no issues with the distributor and clearance.I have one on my 82 with internal coil vacuum advance HEI and 6AL box(mounted under dash)with no problems.
1982 Z28:355,4 Speed,Lots of bolt ons
the only problem that u will have is if u still have the ac pump then thinger on the belt. becuz i took my ac out becuz i noticed that if i get that it will be hittin the ac pump, so like the only problem u will have is the ac pump if u still have ac but if u dont its just a matter of lining things up and drillin. hope that helps a bit.
mods to car
new ignition system, edelbrock intake,600 cfm q-jet,th-350 tranny, used black interior, grant stering wheel, accel plugs and wires, hookercat back, b&m shifter, emmission delete package, computer delet package and soon ac delete and in future-- hooker sump comp headers, posi rear, drag slicks and all new rims probably weld rims, line lock, 8 point roll cage, strut tower brace, drag shocks, sfc, new edelbroc 600 carb, nitrous and a weiand supercharger or a 350 or 400 block
mods to car
