exuast cut outs anyone got them?
if so did u like it? pick up much time?
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
2000 tci stall
700R4 with B&M shift kit
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
msd6AL
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
2000 tci stall
I have cutouts right after my headers, I took about .1 sec off my quarter mile time with them open compared to going through the exhaust. I think I can even run a little quicker than that with them open because the track was much slicker when I made my best run with the exhaust open. My exhaust isn't stock either, I have a 3in. flowmaster system. I have 2 1/2 inch pipe after each header with the cutouts then a custom made yipe going into a the flowmaster system. I like my cut outs a lot, its nice to be able to run open headers at the track when I want to without unbolting the exhaust. It only takes a couple of minutes to unbolt the plates from the cutouts so in my opinion they are worth it. Some might say you need back pressure but from my experience my car runs better with the exhaust open. I have a few pics of my exhast on my website, not the best pics but it will give you an idea about my setup.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Flowmaster 3inch exhaust system, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
M/T ET street tires
I am running a cut out where my converter used to be, right after my Edelbrock y-pipe. Time wise it is worth about .2-.3 tenths. That shows you how restrictive a single 3" exhaust can be.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified CHEVY DEALER Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Terrell351
06-13-2021 01:13 PM
db057
08-11-2015 10:11 PM
