Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
MSD Digital 6 or MSD 6AL?
Old 11-13-2000, 12:59 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
This is what I emailed to MSD Tech:
I cannot decide whether I should get the MSD Digital 6 or MSD 6AL ignition
for my engine. I have a 1991 Camaro Z28 with a nice L98 TPI engine mated to a World Class T5 5-speed. The current mods can be seen on my website here: http://www.socal-fbodies.org/members/kevinl2.html
I recently missed a shift at the track, and over-revved the engine, hitting
the rev-limiter in my PROM at 6500 RPMs. I broke several valve springs in
the process. I am rebuilding it now, adding an LT4 HOT cam, SLP 1 3/4"
headers, and TPIS intake manifold and runners. This car is my daily
driver, and sees 1/4 mile drag racing about once a month, and canyon carving thru the hills about twice a year.
Which ignition box would you recommend for my setup? I like the features of
the new Digital ignition, plus it has two rev-limits. I could use the
second one for launching at the starting line. But is it overkill for me?
Would I be fine with a 6AL? In either case, I will use the MSD Blaster
Coil as well.
Anyone have an opinion for me?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited November 13, 2000).]
Old 11-13-2000, 01:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Considering that the Digital 6 is about $110 more, unless you actually need the second rev limiter or retard functions, i'd say just stick with the 6AL.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old 11-13-2000, 07:15 PM
theformula's Avatar
Not familiar with the digial ignition but if you have the extra cash to blow get it.
I have the MSD6AL and love it. Heres a little tip. Buy the shftnnoid adjustable rpm limiter from JEGS for $20. Its adjustablefrom 0-12000 RPMs. I hate JEGs, but thats where i got it from.
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (42psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges...ZZ9 cam (i still have to install it )
[This message has been edited by theformula (edited November 13, 2000).]
Fanatic1074
10-03-2022 05:57 AM
sheachopper
07-31-2019 11:27 AM
RedLeader289
05-28-2019 01:47 PM
meeklay812
10-01-2015 03:46 PM
Eric-86sc
09-28-2015 11:37 AM
Quick Reply: MSD Digital 6 or MSD 6AL?
