is the MSD billet HEI distributor THAT MUCH better than stock???
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
is it only worth it to get the MSD one if i absolutely have to replace my distributor? in other words, is it worth ripping out a perfectly good stock GM unit to replace it with a 300 dollar MSD one?
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
[This message has been edited by Z28 Boy (edited November 29, 2000).]
-brian
1991 Camaro RS
Brian's 1991 RS
I'd say no. I looked at the $300 MSD for my new 350, but I asked myself the same question. A distributor really only works one way. Not much room for improvement or modification. I seriously doubt that an expensive billet shaft is going to make any difference in spark power or even horsepower.
I went with a brand new stock GM small cap distributor for only $140. Done!
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Yea it will get more spark after Redline, but if your best power comes before redline then why buy a piece of equipment that never sees any use that it was built for. Kinda like buying a Ford Excursion, and driving it in the suburbs all the time
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock will soup up when i get some $$$$$$$$$$
The Summit complete HEI with coil/cap/rotor for about $150 is pretty good setup for most people. I usually buy the GM complete HEI (about $225 from SDPC???) and they have worked out well, too. The GM module seems to rev a little better and give better dwell characteristics than aftermarket replacement HEI ignition modules (not the HO modules like MSD/Accell/etc... They are ok but not worth the money over the GM module IMO)
