Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Where can I buy POR-15?
Old 05-20-2008, 09:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
wWhere can I buy some? Is it available in any stores?
Old 05-20-2008, 10:17 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Where can I buy POR-15?
i buy all mine off of ebay.
Old 05-20-2008, 10:19 PM
taylor740i's Avatar
Car: 90 IROC-BLACK/01 BMW 740I SPORT-RED
Engine: Ls1
Transmission: 4l60e
Axle/Gears: 4.10
u need to get an eastwood products catalog.i started getting them after ordering tons of stuff thru different companies,ie. jegs,summitt,classic industries,lmc......ive seen ads in hotrod mag. also.
Old 05-20-2008, 10:41 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Some auto parts carry it, just have to check.
Old 05-20-2008, 11:17 PM
89RsPower!'s Avatar
does it come in spray cans?
Old 05-20-2008, 11:51 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
You could always go to their website:
http://www.por15.com/
Old 05-21-2008, 12:17 AM
madhatter's Avatar
the best way to get it is to call auto body supply store in your area, if you buy it off of the web you have to pay shipping, and i want to say that pro-15 website charges a ridiculus amount to ship it, i want to say it was like 20 bucks shipping for a gallon. i get it from a local body supply store and they only charge me what it goes for on the website + taxes so thats the route i would go.
Old 05-21-2008, 12:24 AM
madhatter's Avatar
no, however they do make a reducer for it where you could spray it through a spray gun however this **** is permanent you get it on anything, it doesn't want to come off, so they say it can be sprayed but i think that would be to messy and to much of a pain in the ***, brush it, or cheat by getting the really fluffy rollers used for paint brick or other porous material and used that. i found that that was easier to do thing like the bottom of a car, atleast it keep you away from drips when using it over head
just my
Old 05-21-2008, 09:29 AM
86NiteRider's Avatar
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Which supply store. I am in Chicago and would go to that store. I just ordered the small pint kit for $20 + shipping but would like to pick up the gallon and avoid shippin cost. As long as gas to et it is not more than shipping.
Old 05-21-2008, 10:50 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Do you know how much a gallon of Por-15 will cover?? You could be using it in your next life.
Old 05-21-2008, 11:21 AM
TREK's Avatar
Car: 1979 vette
Transmission: th350
And i believe that stuff has a shelf life of about 6 months after its been open.
Old 05-21-2008, 04:14 PM
89RsPower!'s Avatar
how much do you think I would need to do the floor pan, wheel wells, and engine bay? Does anyone have any pictures of an engine bay painted with it? Does it look ok or do you recommend painting over top of it?
Old 05-21-2008, 05:16 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
My 2 cents when working with POR..Be VERY mindful of the instruction that says were gloves and protective clothing unless you like the appearance of dark nails and mole like blotches on your skin. Time, a blowtorch or laser removal is needed to get this stuff off. Also will bubble slightly in high humid conditions so wait for a dryer day
Old 05-21-2008, 05:41 PM
DJP87Z28's Avatar
I would say about one quart for starters. Unless you have a empty engine bal it is going to hard reaching everything.
Old 05-21-2008, 10:03 PM
madhatter's Avatar
my car is a full resto project at the time so i am por-15 every thing, i talked with some body guys and they said that a gallon should allow me to cover all of the underhood, floor pans and wheel wells, i am also going to por 15 my roll cage and inside of the car, i guess i figure now that i have the car 100% stripped now would be the time to do it, i will post pictures of the under hood in a little bit, its not finished yet, still have to remove the master cylinder to get that part, i also want to mention that the black por 15 is glossy so i looks really good.
Buds auto body supply store in summit, i live in oak lawn so its like a 20 minute drive for me. out the door after taxes it was 151 something for a gallon. make sure you call ahead and make sure they have it, i called and they had it the next day for me to pick up
just on a side note buying three quarts of por 15 is more expensive than a gallon and two if you buy a gallon, and it dries up the trick is to put a screw through the top and side, that way when you want to use it, you pull the top screw to let air in, and the side screw to let it come out. it works try it
Old 05-21-2008, 11:00 PM
madhatter's Avatar
Pictures of half done engine compartment
Old 02-07-2012, 08:36 AM
advancedrust's Avatar
Advanced Rust Protection carries the full line of POR-15 products and has only $5 shipping on all orders. Orders placed before 4 PM EST ship out the same day. You can order easily online, or call with any questions on how to best complete your project with POR-15. I think you'll find this is one of the quickest and cheapest way to get your POR15. Check out the specials for even more savings!
Old 02-07-2012, 08:51 AM
User Error 87's Avatar
Car: 1987 Trans AM GTA
Engine: 5.7 TPI
Axle/Gears: 3.73 POSI
Attachment 157350
Attachment 157351
Attachment 157352
wow that looks really good
Old 02-07-2012, 05:41 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i bought some at car quest that sold auto paint.
Old 02-07-2012, 07:02 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Attachment 157350
Attachment 157351
Attachment 157352
Well you sold me. Deff going to going the same route you did. Gallon size it is.
Old 10-14-2013, 07:59 PM
berlinetta1983's Avatar
Car: 1984 Camaro Z28 / 2010 Camaro LT
Engine: Gen IV 454 / LT1 3.6
Transmission: TH400 / 6L50
Axle/Gears: 3.42 LSD / 3.27
I'm thinking about buying this for my 85 berly to do the inside/outside of my flloorpan. Is it really easier to use a brush rather then spray? Also would I need to prep it just like if I were painting it?
P.S. Has anyone ever seen a motor mount break and cause the driveshaft to put a tear in the trans tunnel?
Old 10-14-2013, 08:22 PM
zenish's Avatar
Engine: 305 tbi
my car quest carries it.
Old 10-14-2013, 09:18 PM
I haven't checked any parts stores yet. Theres only a couple of car quest around here and none of em are very close to me. I'll prolly just get it from my buddy that owns a body shop since he'll be fixing my tranny tunnel. YAY! LOL
Old 10-16-2013, 10:44 PM
madhatter's Avatar
You need to degrease the area is if painting, and use some thing to ruff the area up to give it some thing to bite into if painting over paint.
As to the second question I have torn up a trans tunnel with a broken trans mount. engine mount doesnt help, but wont give you enough bounce factor to hit the tunnel unless the trans mount is broken as well.
Old 10-16-2013, 11:51 PM
Unlimited's Avatar
The old school guys like to brush it, newschool would say spray
Old 10-17-2013, 12:39 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Amazon.
Old 10-17-2013, 01:55 AM
madhatter's Avatar
Oh forgot to mention, brush all the way. POR 15 is a PITA to get to spray right and the clean up is a bitch. Experienced that misery once would not try it again.
Old 10-17-2013, 05:11 AM
jmpowie's Avatar
Car: 91 canaro rs
Engine: 5.0
Transmission: 5 speed
just my
If you do spray it, use a cheap throw away gun. If the tip drys when spraying POR-15 is very hard to get out of the gun.
also it has no UV protection so if sun light hits it the POR will peel and turn gray.
Old 10-17-2013, 08:41 PM
Thanks for all the input guys! I'm gonna just brush it sounds like less of a hassle. As for the trans mount I don't know honestly. I bought the car with engine/tranny gone but the passenger side engine mount is gone. I can literally wiggle it around and probably pull it out if I wanted to.
Old 10-18-2013, 07:01 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
As long as you go smooth and put enough on, it will self level really really nice for you. I used to use throw away cheapie brushes, but now I get slightly better ones. Main reason being that Por-15 is a sticky sticky coating, and the super cheap brushes lose strands and trying to pick those out after youre done brushing is not fun.
Get a decent brush...just a little better than the little $0.25 ones, take your time, cover anything you dont want it on, and go to town. Try not to go over the same spot too many times and it'll look great when it dries. Dont fret too much over how it looks right after brushing. Give it some time.
The parts that Ive done with it, even years ago, still look pretty close to powder coat, and they're TOUGH.
J.
Old 10-21-2013, 08:38 PM
Thanx for the help guys!
BrianChevy
Wheels and Tires
08-08-2019 02:16 PM
Reid Fleming
10-10-2015 09:56 PM
Agent507943
Firebirds Wanted
10-02-2015 07:18 AM
IROC ZELLER
09-29-2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
09-28-2015 11:55 AM
Quick Reply: Where can I buy POR-15?
