More super ram questions.
I just found a guy who has a used Accel/LPE super ram intake setup. He says that it is about two years old and has about 15,000 miles on it. He says that he went two a miniram and has just had it sitting there in his garage for two years. He says that it came from LPE and has already been ported and each piece port matched to the others. He wants $700 for the whole setup and says that the only thing left to do to them is to port match them to my heads. Is this a good deal. Will stock 22lbs per hour injectors give this induction setup the juice it needs?
What cam should I go with. This is a daily driver and for now has to use my stock 305, 5spd chip. I can't afford to do everything at once you know. I'm shooting for 375hp and 400-410 ft lbs at the flywheel. Am I on target.
1989 GTA TRANS AM
305 TPI, 5 SPD
SWAPPING TO TPI 350 NEXT MONTH.
1989 GTA TRANS AM
305 TPI, 5 SPD
1 Post
Car: 89 IROC-Z
Engine: 383
I would offer him a little less than $700. I paid $750 for my setup new, but it wasn't port matched. As far as a cam I would call Comp and talk to them about their Compucam line.
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
Ecklers corvette parts and acces. has them for 695.99, i got mine from a local speed shop for 725.oo (gotta support the home team, lol)
87GTA 355TPI,A4 shooting
for low 12'
for low 12'
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
A superram is a little too big for a 305. you would not be buying yourself much. The superram was designed for the big-inch motors 350 and above. If you have no plans to build a bigger motor I would just get a set of big runners (TPIS or Arizona Speed & Marine) and port the base. A superram is a bit of a waste on a 305.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
Karl Hunter
Hunter Motorsports
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Im guessing that price includes the intake, plenum and runners. At that price its a good deal. If you guys are getting the whole setup for unde $700 your getting a steal.
Mark Lock
- 86 IROC-Z - My car, mods and ET's
- -= IROC Online =- - The site dedicated to the IROC-Z
Mark Lock
The intake is going on the 350 I am having built to replace the 305. Yes the setup includes the lower intake the plennum and runners. It was bought through LPE(lingenfelter) and all the port work was done by them. Each piece has been port matched to the other. The plennum and runner kit from Lingenfelter is 499 and the lower intake is around 600(not sure on the exact price.)
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Rob.. that is a good deal with the intake included. I would go with the LPE 219 cam if you are using a roller block. Or the LPE 213 if you are going with a flat tappet cam. After all the are designed for that induction system that takes some of the guess work out of it.
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Mike
no green
01-09-2016 09:22 PM
Royal_Z
09-30-2015 08:45 PM
Dragonsys
09-25-2015 03:51 PM
