quick ratio steering boxes
1 Post
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Anyone know of the quality of Detroit Speeds Steering boxes? I am doing a complete suspension rebuild will all new spohn/umi parts and I figure I might as well replace the gear box now while everything is stripped. Mine probably has 170k miles right now so would you agree it would be a good idea to do it?
http://www.detroitspeed.com/productp..._gear_prod.htm
Are there other quick ratio boxes that anyone can suggest? This one is pretty damn expensive and also recommends purchasing two other parts (you will see on the link above) which makes this turn into a $800 swap
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: quick ratio steering boxes
I just rebuilt mine. It's not that hard and it cost $40. do a search for steering box rebuild/rag joint and pitman arm.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
I put a billet AGR box in my car and I love the thing. No more on center play. Steering is very quick and tight
1 Post
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Not clear what quality/cost you're constrained to,
but here's my experience.
As part of restoring the Formula's front suspension,
steering box was going to be included, and I wanted
to up-grade to quick ratio. Well it turns out that the
(originally equipped)WS6 suspension package included
q-r box, so I was able to get a re-built unit from the
local Car Quest. I can't remember how many turns
lock-to-lock , but I was very clear w/ the parts counterman,
that the delivered unit had better be the same as my old one.
And so it was... I don't have the receipt immediately at hand,
but either $120 or $180 comes to mind.
(Biggest problem was the huge nut to remove the steering arm.)
Good luck.
kk
Good luck.
kk
backtothe80s
09-05-2015 12:39 AM
