Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Which Hood should I go with?
Old 11-23-2009, 02:27 AM
  #51
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Which Hood should I go with?
Originally Posted by C-Titan
I Love That Hood... Just scared to pull the credit card out of the wallet, haha...
Amazing car by the way, one of my favorites on this board...
Like every aftermarket hood I've seen it has some fatal flaws. Even my own cowl is a love/hate thing for me.
But that hood, the cowl uses the factory accents on the hood as a basis for its outline which is great, but for some reason on a car with a lot of sweeping angles and sharp curves, they make the top of the cowl a big shapeless bulbous mass. Why? If You could join that sunoco hood with the SS hood's sharper transition to the "roof" of the cowl, it'd look a lot better.
Old 06-10-2017, 01:05 PM
  #52
Yfc_sean's Avatar
Originally Posted by Blew-By-You
Had to agree here, its rarely seen, plus follows the normal lines of the hood.
Where's you get the wide cowl hood if you don't mind me asking
Old 06-10-2017, 04:09 PM
  #53
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Sunoco hood....you can pre order one form Hawks third Gen.
Old 07-25-2017, 03:54 PM
  #54
Jeff TX's Avatar
Car: 1988 Camaro IROC-Z
Engine: Dart 427 w Miniram and AFR 225
Transmission: Stg 2 LT1 T56 w/ Spec Stg 3P Clutch
Axle/Gears: QP 9" (3.89) w/ TruTrac
Does anyone know if the SS hood provides additional clearance? Or is the whole scoop purely cosmetic? I know it doesn't function for air intake purposes
Old 07-25-2017, 08:47 PM
  #55
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
To me the best looking hood is the stock IROC hood. Obviously, there are times when extra clearance are needed but I don't really like the look of any of them. The cowl induction hood on the blue/silver stripe car is about the best I have seen. The issue for me is when an aftermarket hood is on an otherwise stock bodied car just looks out of place. I am not bashing anyone's look because that's kinda the purpose of hot rodding, make it your own and if you like it that is all that really matters.
If I needed extra clearance I would try to take a stock IROC hood and modify it to give the added clearance but still look stock-ish. From an air induction standpoint I would like to have a front opening scoop like the fourth gen SS's or TA's. I have seen some like this on Firebirds that looked good but I don't know if the Camaro could pull it off. Just my opinions.
Old 06-09-2020, 11:02 PM
  #56
1badcj8's Avatar
Car: 89 Iroc Z G92
Engine: 5.7 HO
Axle/Gears: 3.43
Old thread but I have questions... So I like the 2 inch cowl and the SS hood BUT I'm not finding a Steel SS hood which is prolly what I would like and I had gotten a Duraflex hood for my Built Grand Cherokee and it was junk plane and simple and all that pop up are the Duraflex. What have you folks found? Thanks
Old 06-10-2020, 10:14 AM
  #57
dbrochard's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
There is no steel ss hood for these cars. You're options are the hawks one, the duraflex, or the ascd hood. Hawks and ascd will both cost you close to $800 with shipping
Old 06-10-2020, 02:35 PM
  #58
1badcj8's Avatar
Car: 89 Iroc Z G92
Engine: 5.7 HO
Axle/Gears: 3.43
Thank you sir... Thats kind of what I thought for steel so, With them being that much I'm thinking it wont be an SS
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
Quick Reply: Which Hood should I go with?
