THE Best Air Filter
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
THE Best Air Filter
So what is the best air filter out there? I have been told K&N is great by alot of people because of hp gains. But I have also been told that it lets in alot of dirt and can virtually end up destroying your engine. People have used the motto "they last a million miles because you remove them after driving for a few weeks because you need to rebuild your engine". So are there any other air filters that offer performance without grenading the engine?
Re: THE Best Air Filter
I have had K&Ns on my car since '94-never any problem
with dust getting past the filters and i watch this close.
Also,at least in my case,a C/F,the filters fit well and seal
to the housing perfect.
I recon they flow well,fit well,and filter well
Car: 1987 Monte Carlo SS
Transmission: 200R4
Good ole paper filter.
The rest are gimmicks to separate you from your money.
Bob the oil guy did many a test on filters and found gimmick ones allow alot of dirt particles though. What do those particles do? Know one has really answered that question realistically, but makers like K&N also sell wraps for high dust conditions which tells me it can do harm.
The ony H.P. gains to be had is if your current filters area is to small for your air draw now needed due to mods or it was dirty in the first place needing a new one.
Does anyone remember Stacy Keech doing a dyno test of a K&N setup on a truck?
Well there were no gains to be had until he opened the good and allowed cooler air to enter which he them ducted that system through the fender well and then lost his job because the sponsor got pissed. Thats why he has a new show!!!!
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Do not use an oil bath filter. They have NO performance advantage over paper, they let grit into the engine, the oil mist will damage your MAF, and the are messy to clean and re-oil.
Buy a paper one for $8 and spend the difference on a bottle of Johnnie Walker Black. This way both you and your car will be happy.
Car: Blue 86 IROC-Z
Engine: 305 TPI, Soon a 355 TPI
Transmission: Auto, Soon a WCT-5
Axle/Gears: Nine Bolt, 3.42 posi
I have to respectfully disagree; I have used K&N on every vehicle I have owned for over 25 years and have never seen any evidence of dirt entering the engine through the air filter. In my younger (and stupider) days I used to ride and race dirt bikes, off-road bikers swear by K&N filters which is an environment significantly worse than you will ever encounter in a street driven car, once again; no failures related to dirt entering the engine.
Admittedly the “seat of the pants” dyno can’t discern a big increase in horsepower but, I think anyone thinking they are going to see “big” horsepower gains just by changing the air cleaner is a little naive. In my opinion the money I have saved over the years, as well as the peace of mind of having a quality product protecting my investment; was worth every penny in my mind.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It's not like there's going to be sand on the dipstick if you use a K&N filter. Just because you cannot see the grit doesn't mean it's not there. And going a few years without an engine rebuild is hardly conclusive evidence that everything is o.k.
This is your engine, you can do whatever you want to it. Personally, I do whatever I can to keep the dirt on the outside.
You can try to talk the OP into using an oil bath filter. But this topic isn't worth debating - use a paper air filter.
Engine: gone
Transmission: gone
Axle/Gears: gone
They actually say that the k&n filters do not filter as well until they are dirtier. That's why they dont recoment serviciing them to like 50k miles. Ive been using one on my car for 5 years now with no problems. nearly 60k miles.
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I good-high quality paper filter changed (or at least checked) at regular intervals. Don't waste your money, or neglect your car.
Transmission: 200R4
Link to flow data
http://www.bobistheoilguy.com/cms/in...d=61&Itemid=70
Link to filtration
http://www.bobistheoilguy.com/cms/in...d=66&Itemid=76
Link to filtration
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Used K and N for 15 yrs using paper now. NO sotp advantage I mean how many motors need to flow 2000 cfm?
550chp cant tell the difference between paper filter or no filter at all that should tell you something.
What is the OEM air filter for the Camaro? Anyone have a webpage for it?
Engine: gone
Transmission: gone
Axle/Gears: gone
did you read the article bob is the oil guy did? Thier is not that much of a difference in filtration. Just use the biggest filter you can fit and be done with it.
I read the article but I still want to know what the OEM filter was because if the Norwood Ohio plant thought it was a good enough filter to put in a muscle car then it is good enough for me.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Been following this thread??? WTF either spend the $ on a performance filter (K&N) or just go buy a normal airfilter...
Engine: 5.7 TPI
Yes, those are your 2 options. You aren't going to get both camps to come to an agreement....not ever. Do your own research, and do what you feel is right. As for my opinion, i already stated it earlier in the thread.
Alright but what places can I get the AC Delco filter? I already checked Autozone and they dont carry it and O'reilly's you need to call to see if they can get it or not. Would NAPA carry it? I know they carry alot of stock parts but not sure about the air filter.
JamesC
Engine: gone
Transmission: gone
Axle/Gears: gone
So lets do some math. A kn filter for a 305 tbi, say 40 bucks. Recharge kit. 15.00. 55 dollars. You can get 4 services out of the kit. So that'd be equivalent to 5 filters.
A stock replacement filter, say from wix. About 10 dollars. 5 filters is about 50 dollars.
5 filters later, your at 100.
5 filters later for a kn your at 1 and a fifth recharge kits. so basicall two recharge kits. 30.00....total of 85. With 4 air filter services to go.
This is assuming that a stock filter for a 305 tbi is around 10. If its less then the math is a little different.
you can always factor in time to clean into your equation then also. If that's the case then the difference in money isnt worth the difference in time. So the paper is a better option.
I made cases for both. Hopefully it wasnt too confusing. Haha. Good luck with your decision.
Car: 1987 Black IROC-Z (SOLD)
Undercovver estimates are little misleading on the (4) services per recharge kit. By that statement you are incorrect (unless you live in a dustbowl). If you clean the
filterss once a year or per K&N's instuctions that recharge kit will last longer then your car.
Engine: gone
Transmission: gone
Axle/Gears: gone
Then its cheaper than I thought! Good! I am pro-K&N! sweet. When I service my flow thru lid and filter following instuctions I get about 4 services out of it.
Engine: gone
Transmission: gone
Axle/Gears: gone
I know. So therefore by those tests. the k&n flows a little better. But filters a little bit less efficienctly. So I guess it depends on what you really want! Back to the main point of the thread. Just put what you want!
Engine: 5.7 TPI
If money is no concern, buy the K&N filter and throw it away every 6 months and buy a new one.
HA!
I should have went to bed a long time ago lol. G'Night all
HA!
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
It would be interesting to use a K&N air filter until its dirty anough like K&N recommends, until its filtering capacety matches a OEM paper filter.
And then perform a flow test and a 1/4 mile test.
Meaning that I've run K & N in the past, but I choose to use paper currently, and my choice has nothing to do with cost. At any rate, the debate isn't likely to change anyone's mind. Good luck to all.
JamesC
JamesC
Engine: 4++,350 & 305 CIs
If I remember correctly, didn't most car makers used to use a oil bath type air filter?
I think they probly switched because of cost and ? i'm not to sure i wasn't around then.
Engine: 5.7 TPI
You are correct. I was poking fun at the absurdity of the thread. Its the same with oil, no one will ever change thier mind. No reason to have these threads anyway.
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
I personally saw no HP gain on dyno (of a stockish 2000 Z28) from Fram paper, to K&N to no filter at all. All dynos were within 1-2HP across the entire range.
Having said that, I use a K&N conical on both my L98 Formula and C5Z06.
You can't lose with either set-up as long as you keep them clean.
The truth on K&N filters by David (The Wizard) Vizard. If you have read his books you would know this guy knows what hes talking about. Skip to time mark 5.00min. This guy writes all those books on how to make HP with SBC's. The explanation last 5 minutes or so. http://www.youtube.com/watch?v=F1BZg6aCGd8
If you read his books he also goes on to mention how they smooth out incoming turbulent air and how that can affects atomization of the fuel/air ratio and HP gains from it. Just some food for thought. Also in one of his books he includes pics of his third-gen Z.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
I just got a new 4 inch K&N element and breather for xmas and I couldn't be happier. What a beautiful assembly this is, and it will work terrific too I am sure.
Ill jump in only because I use a filter that I didnt see listed up above in my scanning of the thread.
I ran a K&N for a while on my LS1 swap. It was a 4" cone filter. I had numerous issues with my MAF sensor, brand new Z06 sensor, which I tracked down to probable over oiling from the filter when it was made. So I cleaned it, and re oiled it per instructions. And it still seemed to get oil on my MAF sensor. Also seemed to get dirty fast. I wasnt positive that it was the filter causing my MAF issues, so I decided to ditch the K&N before buying a new MAF to see what happened.
I switched to an Amsoil Dryflow filter. Seemed to have good flow/filter specs, and best of all, no oil. Just blow it out from the inside with compressed air or vacuum it. Maybe it was just me...but as soon as I installed it my MAF problems disappeared and the car ran trouble free. I never had another MAF code, and I never had to clean the MAF out with cleaner. Its blue color sort of threw me off a bit, but after a while I kinda liked it.
Granted this was on a custom intake with no bellows or any stock type parts beside the MAF. So you guys with stock motors and stock airboxes might have different experiences. Not saying I wouldnt buy a K&N for my daily driver Jetta or anything. But for me, it'll likely be OEM paper or Amsoil filters from now on in my cars.
J.
J.
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh yeah they say they could dirty your MAF with the oil especially on some applications where the filter is directly next to the MAF. But say on a stock TPI setup, the two square filters in the airbox, to the MAF. Doubt any harm can come of that. MAF sensors can get dirty with a regular filter too and act crazy also. But I have seen the Kn do that for sure.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Since the MAF has been mentioned a few times on this thread I thought I would ask "what are the symptoms of a failing/dirty sensor?
Engine: gone
Transmission: gone
Axle/Gears: gone
Just odd symptoms maybe a little hesitation, havnt really seen a no start from it. but hesitation, surging, poor fuel economy etc..
#42
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
The filter dispute is downright silly. If it works use it, if it doesn't get a different one.
And for those of you and your "just cause you can't see it doesn't mean its not there" are out of your mind. Drag cars with turbos and blowers don't even have air filters and they have some of the most expensive motors, you think they are worried about dust particals?
I have never seen a motor with any kind of working air filter blow up because something got past it. I run dry K&N filters for that reason.
#43
Pretty sure those top fuel drag cars get rebuilt every full throttle pass they make. Not sure if its a full tear down or partial but those motors dont live very long making 7k HP. and they are backed by multi million dollar sponsors. Those guys are going down the strip in a handful of seconds compared to road race cars where there is constant debris being kicked up and other cars out in front and endurance is a huge part of road racing or even WRC/Rally. Pretty sure those guys are running air filters. Just 1 cylinder of the 8 from a top fuel motor makes 750HP, bout the same as a NASCAR motor. (someone correct me if im wrong)Even NASCAR motors are only meant to live for 800-900 miles before being rebuilt again and im pretty sure they use filters. 500 miles for the race, the rest for qualifying and shakedown i would assume.
#44
#45
Engine: gone
Transmission: gone
Axle/Gears: gone
#46
Car: 1992 camaro rs
Engine: 305ci v8
Axle/Gears: stock
There's also the option of getting a spectre build your own cold air kit like the guys from horsepower tv did for their 305 tbi. the spectre custom cai, full update on synthetic fluids, spark plugs, wires, distributor, a hypertech chip and thermostat, and the car gained like 20 hoeses, 17 ft/lbs of torque, and 3 miles to the gallon. They ended up spending about $600 for all of that. You could always do that system, it looked like a really nice setup imo. I'm considering doing it myself. Though I haven't heard very much about spectre as a company. Only heard about it from that show, and my coworker who's big on offroading, but he treats his jeep like **** so I'm personally not to trusting of his opinion.
#47
Engine: gone
Transmission: gone
Axle/Gears: gone
spectre has always been known for cheap stuff. mostly for engine dresssing ex. chrome water necks, timing covers etc...they also sell a different setup that I think is better jegs offers it. it has an airbox, tubes etc...
#48
What the other guys said about the drag cars is true. They get gone through every pass more or less. And there isnt much dust/debris going on at the strip. Generally pretty clean air. But in traffic/road race/off road applications, you better believe a good filter system is important.
Wanna see some damaged motors? Run with some of the off road guys for a while. I was using a Spectre filter on my cherokee for awhile. Until a fairly decent sized piece of dirt got in and tore one of my valve seats up. Found it when doing the tear down sitting right on top of the valve. After fixing the motor, I ran a K&N (no maf sensor) WITH a foam baffle around that. And I cleaned that sucker regliously after every off road trip. It happens trust me. How you are using the motor effects your chances of it causing issues. A dry K&N is better than a cheapo spectre IMO. Heck stock paper is better than those if you ask me.
J.
#49
1 Post
Car: 91 Trans am
Spectre is made in china garbage. I can understand that for some people a ducting piece is a ducting piece no matter were it's made, as the main difference is the price and the social-economical consequence and not the ducting capacety.
But a garbage air filter no matter how cheap, is a bad choice.
#50
Car: '89 GTA
Engine: 5.7L LS1
Its not a dispute really... We're all sharing experiences and knowledge. Thats what this forum is for. Some of us have "been there done that" and like to help the guys that are just going through something for the first time. I know if I knew nothing about air filters Ide like to read info/opinions/experiences before making a choice. Just sayin...
J.
J.
I wasn't just speaking of top fuel cars, those things are pretty much warped after every run. Now as for off road that should be pretty much a no brainer to have a very good filter, and multiple inlets and filters IMO because having a filter caked with mud is how you screw up a motor.
But for street and track use, which is where pretty much everyone here is going to be I don't believe you can go wrong. Of course for me whether its speakers, air filters, or even remote control cars, if it says 'Made in China' I throw it away.
