Changing Plugs w/Headers? Buy a Go-Thru Socket Set and Ease the Pain
The 21-piece SAE/Metric go-thru socket set from Harbor Freight (#67974), seen below, makes short work of changing plugs in the close quarters that often accompany headers. At around $25, the set is a bargain (around $19 or so with a coupon). Sears makes a much larger and more expensive set, Max Axess, if you’re interested.
http://www.harborfreight.com/21-piec...set-67974.html
JamesC
JamesC
1 Post
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Changing Plugs w/ Headers? Buy a Go-Thru Socket Set and Ease the Pain
i don't see a spark plug socket.will these work with spark plugs?
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Nice find, James! I bought the short header socket from SLP a few years ago... made changing plugs much easier. Either way, it's better on your knuckles
Engine: 4++,350 & 305 CIs
I made this back in 92-3? after I put my SLP headers on. Shes been a great tool..
2 Cheap 12pt box end wrenches, cut, welded, an heat bent to work like a champ in those pesky hard to reach spots.
Necessity is the mother of invention. Looks useful. I like the ratcheting ability of the go-thru, however--which, BTW, isn't as fine as the Sears' version, but works very well for the application at hand.
JamesC
JamesC
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have that set from Sears. Gear-Ratchet pass through sockets and they do work very nice. I stll have to go from underneath to get to my back two passenger side plugs due to the design of my Edelbrock TES headers, but it's much easier with the pass through socket.
Car: 1986 Z28
Engine: ZZ3
Taking off the starter helps immensely trying to get to the two back side passenger side plugs.
Re: Changing Plugs w/Headers? Buy a Go-Thru Socket Set and Ease the Pain
Nice set if you need multiple sizes.
I just bought a cheap spark plug socket from advance. I made sure it had the inner hex all the way down. Then I cut the socket real short then took a drill and opened the end up where the ceramic part could slip through. Worked great for $2.
this is what i use but i dont pay that price since i work at COMP.
http://www.powerhouseproducts.com/ph...rder=relevance
James, do you still have the air tubes on your 2055's? im about to take mine off being i live way out in BFE and "boyh yew gotta purtey mouf"
BTW, you get both socketsfor that price.
I ground off the side of a spark plug socket , it still holds together so I can tighten no problem . I went through plugs a lot because of the warm up cycle not working properly .
When I first put the motor (and headers) into my IROC, I had a rich condition that resulted in me changing plugs every 100 miles. In short order, I managed to get the whole process knocked down to a 25 minute job, including jacking the car up.
A 5/8" ratcheting wrench, and a cheap 5/8 socket cut down just long enough to fit over the back of the plug wound up being a god-send.
That said, this tool kit looks like a great idea in general as well as for plug R&R, so I may give it a try!
Car: 1986 Z28
Engine: ZZ3
The official SLP spark plug tool is/was a 5/8" Craftsman spark plug socket cut down to about 1.5" long and the square drive bored out so the porcelain would slide through. I made my own with a cut off wheel and a carbide cutter, which worked great with SLP headers.
1 Post
Engine: 305 tbi
[QUOTE=JamesC;5064429]The 21-piece SAE/Metric go-thru socket set from Harbor Freight (#67974), seen below, makes short work of changing plugs in the close quarters that often accompany headers. At around $25, the set is a bargain (around $19 or so with a coupon). Sears makes a much larger and more expensive set, Max Axess, if you’re interested.
JamesC[/QUOTE
i just got a coupon for 18.99
JamesC[/QUOTE
I have a similar box wrench that I use :
I made this one way back in the day:
The collar is slid up to get the socket over the plug and slid down to keep the socket from opening when applying torque.
Car: 1986 Z28
Engine: ZZ3
Does the engine run better, smoother, worse? Is the check engine light always on? Gas mileage? Up or down? Or is it exactly the same as when all that hardware was on the engine? Thanks again.
Great tool kit but you spend that money and only need the 5/8 socket to change the plug.
Better off just buying the SLP or power master 2 pc socket set. as it take less space in a tool box.
If you have the time and tools just get a 5/8 spark plug socket with a hex end and modify it.
Good sockets are forged, cutting them to length you can do with a cut off wheel.
opening up the hex head you will snap drill bits all day, you need to use a carbide grinding bit.
but it an hour or less you have the same tool for a fraction of the cost..
Pretty much what I was going to suggest. I have a snap on double offset box wrench set that is invaluable for plug changes.
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
