Intellitronix digital dash on Camaro 1986 without ECM?
Car: Chevrolet Camaro Z28 IROC-Z
Engine: 350 cu 5,7 liter
Transmission: automatic r700
Hi thirdgen members,
Hopefully someone has got the answer to this, I couldn't find any info about it on the internet: I have a 1986 Chevy Camaro Z28, but when they build the new engine in ( 350 ) they removed the ECM and all of its components. I now have the opportunity to buy a digital dash for a thirdgen Camaro made by Intellitronix, My question is: will it work without the ECM or is that computer necessary to operate the digital dash? If anyone knows how this works, please let me know, i'll be greatly thankful for your answer!
Also everybody a very happy en merry Christmas!!
greets Finnie
greets Finnie
Re: Intellitronix digital dash on Camaro 1986 without ECM?
i think it will work without the ECM-just will need the right senders if the intellitronix uses senders different from stock '86 camaro.Welcome to TGO-there are a few other dutch guys on here too
Hi 8t2 z-chev,
Thanks for your answer, I already thought something like that, I have no idea how to come about those kind of senders / sensors here in the Netherlands.... until this past year I visited the states twice a year ( mostly California, Nevada and Florida ), but with my daughter becoming 3 years of age ( full ticket price at any airline ) and the bad economy here I'm not in the position to go "shopping" in the states for these senders. Do you know of a webshop that sells these kind of senders and will ship them to the Netherlands at a reasonable rate?
thanks in advance for your answer, appreciate it!
btw, what does TGO mean ?( I'm kind of a newbe )
TGO: ThirdGen.Org.If the intellitronix guages do use different than original senders and they are not included with gauge panel,you might have to experiment to identify what senders are needed to get correct readings.
Hi,
TGO, first time I've seen this, now I know what it means.... I didn't bought the dash just yet, I first wanted to know if there would be problems ( I have seen threats from people who had a very hard time building these things into there cars and got them to work properly ). The seller will send me some more pictures from all around the dash, so I can see what is included with it, he didn't know much about it, so he couldn't tell if senders were needed or not. I love my Camaro, but I'm no big techno freak so I hope I can tackle the problems that will come forward during the install. the stock mech. speedo that's in my car right now doesn't operate as it should, that's the reason why I want(ed) to buy this digital dash.
Thanks for your advice in this, I will search further for the right senders for my vehicle!
greets Finnie
greets Finnie
Axle/Gears: '01 3.42 10 bolt
Finnie, if it doesn't come with the senders that came with the panel, you can contact the company direct for them. they will sell them individually. the senders that are needed will not be visible at the dash. you need the temp sender, speed sensor, and oil sender. if you get te install instructions from the company it isn't that bad. i just did mine on a '91 this past summer. instructions help loads as they use different wire colors than factory.
1 Post
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
I put Intellitronix 6 gauge digital universal cluster in my 87 Silverado. If you don't have the sending units, then go to intellitronix.com and look at the sending units.
Since you have a cable driven speedo now, the sending unit you'll need is S9013. Temperature sending unit is S8013. Oil pressure sending unit is S8434.
Gas gauge will work with the original sending unit in your car.
Also their speedo sending unit puts out 8000 ppm.
When I swapped in my 350HO Deluxe, the ECM was removed. While removal had no effect on gauges, I did have to reground my cruise control as seen below (Note that the blue and green wires are for the backup lights on a T-5):
https://www.thirdgen.org/forums/engi...-function.html
You may find the following installation video interesting:
JamesC
JamesC
Hi everybody,
Finally the seller has send me some detailed pictures of the gauge and the stuff that will come with it, It's not a intellitronix dash like he sayed in his email before, but instead it's a Cyberdyne dash. I don't know if there is a difference between those gauges, but I posted some detailed pictures of the parts here, can anybody tell me if the sensors I will need are included or not? There are some parts that are attached to to wireing, don't know if they are sensors or what... thanks in advance for your reply!!
They look like my 2001 technologies setup ... Uses stock odometer setup from original cluster, if it is like mine it uses the stock sending units but then uses a inline VSS sensor that connects to the speedometer cable.
These were in a 82 vette though
Greetz Finnie
The 3rd pic is the VSS for the digital speedo. The vss for the ecm is on the back of the cluster but since you don't have a ecm won't matter.
Just put that VSS between your speedo cable and trans and it will drive the odometer gears and provide a pulse for the digital speedo.
1 Post
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Hi everybody,
Sorry to bother you again, thanks again for your reply, but do you think i need any more sensors for it to work correcly? ( I mean everything, oil, water temp. And engine temp. And also the rpm ), or is that part covered with what you can detect on the pictures?
Mine didn't need different sending units
I believe 2001 technologies was bought out by itteltronix at some point. Your pictured VSS looks different then what mine does.
all my gauges worked fine using the stock 82 vette sending units. However can't say for certain your will. The sending units aren't that much anyways. Most you would need is oil pressure sending unit and maybe coolant temp. How much you buying it for?
RPM will just be from one of the wires in the cluster pigtails.
It's offered to me for 50 bucks as is, but the seller has to send it to me, it's to far to collect it personally. So, in total it will be around 60 dollar.
Thats a good deal, bought mine for 50.00 so compared to what they are new you got a deal even if you have to buy a couple sending units.
I also think It's priced right, but I live in the Netherlands, so getting the right senders ( if any ) could be a problem. I visit the states at least once a year, but I think I have to order those by mail, there won't be a store selling those....
talk to a guy named twin_turbo on here, he is from you area and might be able to shed more light on shipping. I sent him a car and TPI system I can't imagine sending units be that much of a issue to send.
The_Phoenix
02-04-2016 07:10 AM
Sanjay
08-12-2015 03:41 PM
beachrodder
08-07-2015 04:27 PM
