assault racing 200cc 64cc chamber heads ( dart copys)
#202
Re: assault racing 200cc 64cc chamber heads ( dart copys)
proheader
#204
i may very well be yanking my heads off after next weekends race and sending them your way for the 227cc 2.055 deal
got those 227's on anything close to 355ci 10.25-1 cr ,fairly mild cam (xe274) hsr intake ? if so what kind of power they making n/a
#206
Car: BUILDING 1985 HARD TOP T/A
Engine: sbc
Transmission: stick
Axle/Gears: GM
I'll be sending my Dart Pro1 head's to you for the 2.100 job..... Sometime after the 17th of this month.
#207
1 Post
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Wow heck of a deal, what kind of power gaines with the 227 porting could some expect over the out of box proheader heads?
#209
Engine: sbc
Transmission: stick
Axle/Gears: GM
I'm thinking the 248's will be the ticket on my 422cid 12.8:1, guess we will see
#210
im buying another set of heads to send off to chad instead of pulling my current heads.
this motor is up and running now but race seaon is over so i cant get track numbers till atleast january , i will however have it out on the street soon after i fix the wiring error int he tailights
sorry about the vertical video
#213
Engine: sbc
Transmission: stick
Axle/Gears: GM
Np, Chad has my pro1's. ... I told him that I didn't need them until February.
Still anxious to see how they come out
#215
Engine: sbc
Transmission: stick
Axle/Gears: GM
Definitely, but they'll be assembled when I get them back. I sent him the heads, valves, springs & retainers ( hopefully Chad won't be to mad about the part's I sent ).
Maybe we can get him to post some pictures of them bare as well.
#216
Project89,
Or any one who owns these heads. What are the proper size length of push rod that go with these heads?
Because the extra think deck it requires a different length push rod no?
#217
The only way to get an accurate answer is to measure yourself so the rocker axis from trunion to tip (or roller tip centerline) is dead perpendicular to the valve stem at mid lift. No other way about it. DIOADIR
#218
#220
#221
Engine: sbc
Transmission: stick
Axle/Gears: GM
I wouldn't use anything under a 3/8", most push rod guy's would recommend 1/2" tubes for a solid roller.
As far as length, the last set I ordered were 8.300" , but as mentioned above, it's different on every engine.
#222
So far I have Scat forged 4340 3.750 stroker crank with forged 4340 6in rods 30 over wiesco forged pistons GT45 turbocharger RPC200cc( dart platinum copys) heads and Assaults hurricane MPFI intake manifold.
The motor will live mostly below 4500 rpms will 3/8 push rods do you think?
#223
Engine: sbc
Transmission: stick
Axle/Gears: GM
With boost. ... I'd lean towards 7/16-1/2", call Manton or Trend. They will tell you what they believe will work best for your application
#224
I guess it depends on your spring pressure and aggressiveness of the solid lobe but 3/8 typically does very well. Thats what i use to 7200 rpm and 30 psi lol but i am hyd roller with relatively mild springs 180/450 lb
#225
Engine: sbc
Transmission: stick
Axle/Gears: GM
Hey Orr, you still running the assault heads?
#227
Engine: sbc
Transmission: stick
Axle/Gears: GM
Oh, was just curious about them. Got a budget build going on. Chad is hooking me up..... I sent him a new set of "old" pro1's to port & he's trading me up to the platinum series + full cnc 248cc runner program, valve job & stacking the springs. ... grand total, 2k
#229
Engine: sbc
Transmission: stick
Axle/Gears: GM
I'd say probably right on point with that. Around 340-350 cfm.
#230
Engine: sbc
Transmission: stick
Axle/Gears: GM
1207 port match?
Going on my solid roller 422 ci sbc
#232
Engine: sbc
Transmission: stick
Axle/Gears: GM
Right on!
If you don't mind, what is your combo?
Just curious as to how similar yours & mine are...
Ya know ci, compression, cam, intake & carb ( just general info, don't have to be exact ). I'm shooting for 7500 rpm (or better), & 700-750 @ the crank + 250 shot of N2o....
#234
Engine: sbc
Transmission: stick
Axle/Gears: GM
Nice!
I hope to be able to get mine together this year.
#235
cars up and running so far ive been really happy with these heads , only been running a few pounds of boost till my 118 fuel gets here so i can dial in the tune but shes an animal and a half
lil lack of low end tq but that was expected to be with my combo with the large heads xe274 and hsr though it is a a bit hard to get a good feel for the heads down low with my 4,500-4,800 converter in the car
#236
Engine: sbc
Transmission: stick
Axle/Gears: GM
That sounds BADASS !
Can't wait to see her go, Congratulations bro.
#237
thanks unfortunatly my racetrack closed down , so she is reserved for daily driver status for now , rmr in slat lake city is about a 400 mile tow for me , and las vegas is about 440-450 mile tow not sure how many times i can afford tow the car to either this year
the track i did have that somewhat close was about 200 mile round trip and cost me about 100$ in fuel for the haul , im hoping they find another location to open up that is closer to me or about the same distance away
#238
Engine: sbc
Transmission: stick
Axle/Gears: GM
DAMN! THAT SUCKS! ! ! !
You can't really blame them, because of idiots that go to the track, sign a waiver, crash & then sue the track anyways & the insurance! OMG!!!
And now everywhere, the cop's are cracking down on street racing!
That's why I'm not building a drag car!
I'm gearing towards open roadrace events, autoX& highway roll racing for top end
#239
Car: 84 sbc
Transmission: 400
Axle/Gears: 373
Man I don't think that will help me none ! I'm here trying to get the facts not opinions ! Is that all u had ? Can u give some evidently truth based facts about the product , bcuz I'm fixing to buy a pair . thanks bud
#241
What would you like to know? ive had my set as cast not ported from 2015? still on the 383 running a s480 turbo. Im a machinist( non automotive) by trade . I went over my set on a surface plate . I dont have my engines build log in front of me but I do remember I was more than pleased with my castings. Are they better than a stock iron head yes are they as good or better than a set of AFRs not even close. All overseas heads arent made the same so do your home work.
diana227vegas
07-08-2016 12:27 AM
