are k&N air filters Bad for your car??
Car: 1988 iroc-z
Engine: 350 5.7L Tpi
Transmission: 700R-4
i used to have k&n air filters in my 88 iroc 5.7 and i had a mechanic who replaced my radiator tell me they are worse than stock ac delco bc they gave off oil or something and caused my mass air flow sensor to become dirty....has any one else been told this? thanks.
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
Re: are k&N air filters Bad for your car??
I've heard that if you use more oil than necessary it could cause problems. I have a K&N filter on my truck, use the least amount of oil to clean it, and have not had problems.
Car: 1988 iroc-z
only TPI engines have mass air flow sensors i believe ....but i do think this mechanic was all GM and pretty anti-aftermarket but he made it seem like my k&n air filters were the cause of my mass air flow sensor getting dirty..Do u think its even noticable changing to K@N filters over stock ones anyway?? should i9 choose to go back? lol
Car: 1986 Trans Am
The oil can be an issue on MAF equipped car.
I would be more concerned about all the dirt they let into the engine. A paper filter has far better filtering efficiency. The oil analysis labs can actually tell if you are running a K+N filter due to the higher Silicon content (sand)in the used oil.
http://www.gmtruckcentral.com/articl...ter-study.html
http://www.bobistheoilguy.com/forums...la#Post2961484
Personally, after cleaning my MAF sensor a few times, I won't use the oiled air filters any more. I either use OEM grade paper filters from Wix or dry flow filters that don't require oil. And K&N does make dry flow non-oiled filters.
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Wow, Thanks for the info/links joshc......
I'm running a K&N in my carb'ed truck and my boss is in his 09 vortex, This explains all the black sooty oily crap I see in the throat of my carb and the same crap I found in his throttle body just yesterday.
I'll be passing along this info, And will change the oil and trash the K&N in mine before it leaves the yard again.....
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
The K&N flow good, but do not filter as well as paper... You make the decision as to the trade off of engine life vs. performance. On the street, they protect the engine rather well & as long as not over-oiled, they work well.
I use them on some of my street cars, but never on my ATV's. The dirt that gets by is incredible.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Mechanic in post #1 would be correct.
Oil bath filters are utter nonsense. They offer NO performance or cost benefit. And they let grit into the engine.
Sheesh.
Sheesh.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
For those of you that have TPI and MAF and are worried about the oiled filters than here’s some of the AEM dry filters that have been mentioned
= http://www.jegs.com/p/AEM-Induction/...2/-1?viewAll=1
Ya your sooooooo wrong, your the type of person
that has never been to the track and done back to
back testing, I have,the filters allow better e.t's and
mph gains in the 1/4.
My latest test is my 2013 challenger from
factory filter to K&N drop in filter the car
ran quicker aand gain trap speed.
Know the facts before you spew total nonsense.
Engine: TBI,5.0
I know this article was written by K&N but if you're going to truly want to find answers at least read this article including the links provided during the article.
There are two sides to most arguments so if you're interested in learning something you need to have information from both sides.
This is K&Ns answer to the accusation concerning the oil and any damage it can cause.
= http://www.knfilters.com/MAF/massair.htm
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Engine: TBI,5.0
Over the last 8 years here with all the videos,articles and discussions concerning air filters IMO comes to this.
A "trade-off" between optimizing a filter for dirt capturing ability and maximum airflow".
IMO a K&N filter oiled properly will flow better than paper but sacrificing a "tiny" bit of its ability to filter as well as paper.Thats an extremely general answer and many circumstances can apply.
All in all I prefer the K&N Style filters not only because they flow well but are reusable and let’s face it when I pop my cowl hood I want to see this on top of my engine, not a paper filter.
There are a few engines on this page that do not seem to have a problem with K&N = https://www.google.com/search?q=engi...w=1440&bih=727
( Partial answer )= http://www.boschautoparts.com/filter...ilfilters.aspx
nonsense, I know cars and I care if products hurt or help
performance.
ya i look back to 1982 when i started using K&N filters. and what things looked like and ran like.. and i will never use a cheap filter ever.
it would be like using 99cent oil filters made in china....
K&N..yes they work...no they dont knock out parts...and us guys who know cars
(have worked for Ford and GM} anytime a dealer puts the blame on anything other then parts just going **** up...there passing the buck... and not wanting to replace a bad part...
and the black oily crap ya see in your carb/tb. that is
reversion..look into it
but its ok... about 90% of the shops now. only have guys who can just replace parts..and have no diagnostic skills.
they have NOT A CLUE...with out the aide a $5000 dollar computer! and it shows all the time.
with a fix this..nope not it..fix this..nope not it..ok we know it's this..nope not it....lol $$$
Car: 88 GTA
Thanks, But that still doesn't dismiss the poor filtering quality. Living in the country (dirt roads/car shows in grass fields) I need all the filtration I can get, Besides I have plenty motor that won't miss what little gain they may provide.....
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Advertising and expensive packaging is what you are getting in exchange for your money with an oil bath air filter.
They are an easy sell to pedestrians like yourself because they falsely claim a 15 horsepower increase, and unlike a real performance upgrade, they can be installed using the tools found in the utility drawer in your Mommy's kitchen. No mechanical knowledge required.
Air filters aren't even a topic that's ever dicussed by real car guys. We just replace them when they show the slightest hint of dirt with a high quality, brand name clean new paper one for $8.
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I had a k&n filter for my TPI, 5.7. It gave me code 36 and the resulting check engine soon light drove me nuts. Once I read about the filter, I took the maf off again and sprayed a little Berryman b-12 chemtool. It went from black to silver ( the insides). Code 36 went away. Personally the oil coated filter only have me headaches. And yes your mechanic had a point. After tearing apart the bay, replacing the ECM, and seeing the ses light for a year, I stand behind that claim.
I ran a K&N drop in filter on my daily (and toy) cherokee sport. Ran it from about 150,000 miles up to a little over 220,000 miles when I sold it. Never had issues with grit or contaminants in the oil, or any issues with check engine lights, and yes, I could tell a difference in stock vs K&N when it came to throttle response(K&N was better), and even got a little better mpg's with the oiled filter.
Now on my carb'd 350 I had a spectre(off-brand) oiled 14x3 filter, no issues, except due to cheap parts the rubber started to dry-rot so I replaced with a good-ole FRAM paper 14x3 filter - couldn't tell a difference at all.
So it may be an application by application thing but that's just my 2-cents.
Transmission: World Class T-5
Axle/Gears: BW 3.45
I'm not sure if I've ever felt a performance difference with a K&N, but I've run them for hundreds of thousands of miles in various cars without issue.
Car: 1987 Black IROC-Z (SOLD)
Talk about K&N oiled air filters has been around for years, with either you Love or Hate them. Myself, I have used the same filters on my TPI system since 1988 (305&350) with NO complaints.
Biggest problem I read about is excess oil, now I still have my K&N recharge kit from 1988 and it is still only one half used. People think they have drench those filters with oil and that is the problem...Read the instructions and they warn about over oiling.
1 Post
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
The proper procedure for cleaning and re-oiling a K&N filter is a somewhat complicated one. A procedure that is rarely followed, shortcuts are taken, resulting in poor performance. 90% of the time, failures and troubles are a result of improper maintenance on the user end, not of the product itself.
Car: 91 trans am gta
Engine: 5.0L V8
Transmission: 5 speed
What about weapon r filters? I know there are made for foreign cars, but I liked the one I used to have
Yea... At least that is what I was talking about.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
So in terms of getting performance advantages with K&N vs stock paper, I just can't see it.
I actually took my air filter off one day since it was looking dirty. I'd planned on stopping by a store and buying a new one. Well I wound up forgetting about it the next day and a few days later went for a drive with the car with no air filter on......I noticed no performance difference for 2 days. At that point I remembered I'd forgotten to buy a new filter. So I did.
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
86IROC112
08-17-2015 02:00 PM
