Throttle body air foil
Car: 1988 iroc-z
Engine: 350 5.7L Tpi
Transmission: 700R-4
i am looking for the right throttle body air foil to buy for my 88' iroc tpi.... I see hawks sells the slp one that boots intake flow by 30 cfm.. but i am seeing other ones online that does 40 cfm by crt perforformance... does any one know the best one to buy?....the one by crt also comes with an air lid gasket? what is that and do i need that?
Car: 1988 iroc-z
Re: Throttle body air foil
i only want the best for my car any help would be great!!...thanks
1 Post
Car: 91 Z28
Transmission: TH700-R4
I have the one by crt. The lid that says tuned port injection has to come off to put in a block that the airfoil screws into.
Car: 1988 iroc-z
does the lid that says tuned port injection go back on? what is that gasket for?
Car: 1988 Pontiac trans am
1 Post
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Put your money to better use and gasket match your plenum and runners, cheaper than the air foil and would probably make more of a difference .
Transmission: World Class T-5
Axle/Gears: BW 3.45
I don't think it's a waste. They are probably worth 1-2 hp, regardless of which one you buy.
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
i did the one that Hawks sells and it took me 20 minutes to install; i don't remember any kind of gasket...
car felt somewhat quicker afterwards, according to my butt dyno
Car: 1986 Iroc Z28
Im not positive what that gasket is for, but I did have a vacuum leak pop up when I swapped out that top plate and tried to skip the gasket. There are usually cheap ones on Ebay..you dont need anything crazy for that.
1992 Trans Am
05-10-2023 07:19 PM
mdtoren
08-16-2015 05:45 PM
