ANNOUNCING GTA 17x9 MESH WHEEL SETS!!!! - Page 7 - Third Generation F-Body Message Boards
Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Thread Tools Search this Thread
Old 08-07-2017, 12:33 AM   #301
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Re: ANNOUNCING GTA 17x9 MESH WHEEL SETS!!!!
Quote:
Originally Posted by wgripp View Post
I can't wait for those 18s!
I think the G-bodies have different backspacing.
seanof30306 is offline   Reply With Quote
Old 08-07-2017, 02:46 PM   #302
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
9" is really narrow to mount a 275 tire on - especially once you go above 17". I know they are for g-bodies, but a 9.5" or even 10" wheel is best.
Wonder if they are making the mounting pad higher as the Hawk's wheels have the same exact design flaw as the OEM 16" wheels when it comes to caliper clearance.
paul_huryk is offline   Reply With Quote
Old 08-07-2017, 10:27 PM   #303
Engine: L03 305 TBI
I'm a little sad to see these guys doing it, instead of Hawk's. Bruce was the only one to step up after YEARS of TGO members trying to get someone to build this wheel. I just can't understand why he did a 17 x 9 when 18 x 9.5-10 was what the overwhelming majority of 3rd gen owners wanted.
Old 08-08-2017, 05:16 PM   #304
paul_huryk's Avatar
Here is the exact reason: 9" fits 2nd gens with stock suspension also. 9.5" won't fit up front without tubular front control arms.
I'll be the first to admit, 18" is what should be made - but as long as someone makes them - they are affordable and strong enough - people will purchase.
Old 08-08-2017, 06:29 PM   #305
Engine: L03 305 TBI
I thought the Firehawk rims were 9.5" wide?
Old 08-08-2017, 06:51 PM   #306
paul_huryk's Avatar
They were/are.
I do have a local friend who has firehawks on his 74, but it is slowly machining aluminum off the wheel.
Old 08-08-2017, 07:01 PM   #307
Engine: L03 305 TBI
They were/are.
OK, I get it now.
I thought you were saying you couldn't get wider than 9" on 3rd gens without tubular front control arms.
Old 08-08-2017, 07:04 PM   #308
Car: 91
Engine: 5.7
Transmission: 700
"we already have drawings submitted for the F body and awaiting tooling quotes. 18 X 9 will be 4.25" back spacing.....back space/ offset on 19x9.5 wheels 4-3/8...."
bk2life is offline   Reply With Quote
Old 08-08-2017, 07:28 PM   #309
Engine: L03 305 TBI
Quote:
Please don't take this the wrong way ... I'm very grateful you're making this rim for 3rd gens.
I'm just wondering why 18 x 9, instead of 18 x 9.5 or 18 x 10?
Old 08-08-2017, 10:05 PM   #310
Car: 91
Engine: 5.7
Transmission: 700
Please don't take this the wrong way ... I'm very grateful you're making this rim for 3rd gens.?
im not making them. read one of the posts above it has a picture of who is making them.
Old 08-08-2017, 11:37 PM   #311
Engine: L03 305 TBI
paul_huryk, can you lobby these guys on sizes/backspacing? They seemed interested in what you have to say,
Old 08-09-2017, 06:25 AM   #312
paul_huryk's Avatar
I have spoken to these guys on FB - they are a G Body shop - wheels are for the 78 to 87 Monte SS, GN, GNX, and Grand Prix, not 3rd gens, although the wheels may fit them by default. Those cars need a similar BS out back - but they do have frame clearance issues in the rear and cannot fit a 9.5" up front without doing a lot of mod work, unlike 3rd gens.
I'm hoping they work for both applications, but they have not released them yet. I also hope the brake clearance is better than the Hawk's wheel - which is similar to the OEM 16" wheel of the same design.
Old 08-09-2017, 02:24 PM   #313
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
They were/are.
Damnit Paul, it's a 73. How many times do I have to tell you. Body style break down is 70-73 (my body style), 74-77 and 78-81
scooter is offline   Reply With Quote
Old 12-20-2017, 08:28 PM   #314
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
Someone had asked in this thread about LS1 brake clearance with these wheels. I put on LS1 front brakes this fall and the clearance is fine IF you use the spacers Hawk's supplies. If you don't, the spokes contact the calipers. I used the Big Brake Upgrade hubs, which are just machined stock rotor/hub assemblies with the rotor rings removed and longer wheel studs. So my track width increased by the thickness of the LS1 rotor hat sections but the calipers still contacted without the spacers since the LS1 calipers are bigger.
GCrites80s is offline   Reply With Quote
Old 12-21-2017, 07:03 PM   #315
Quote:
Do the GTA wheels stick out quite a bit with the LS1 brakes and spacers or are they still tucked in the fender? Any pics?
FAST LiFE is offline   Reply With Quote
Old 12-22-2017, 05:23 PM   #316
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Quote:
Was curious about that myself.
DynoDave43 is offline   Reply With Quote
Old 12-22-2017, 09:39 PM   #317
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
I can't really tell a difference. I have 275-40-17s and there was a rubbing noise the very first time I turned tightly in a tiny cul-de-sac but I've done the same turn several times since and there has been nothing since. I'm almost positive it was the fender liner since the tires show zero damage but the fender liners do. Also it is a reminder to remove the splash guards since I finally don't have to drive on gravel any more. Camber is -0.7 on the left and -1.7 on the right since the left couldn't go any further even with camber plates. The Koni shocks raised the car. I need different springs in order to get more camber. It was the left side that made noise.
Old 12-23-2017, 07:39 PM   #318
DynoDave43's Avatar
My inner fender liners have rub marks from my factory sized tires. So if that's all it is, that's good.
Old 01-03-2018, 04:18 PM   #319
KMK454's Avatar
Car: 1991 Camaro B4C
I finally got a set in black. I love them. I used to want to go 18", but I think 17" is perfect. They fill the wheel well nicely, they're more period correct, and 275/40r17 gives a nice sidewall look. The ride is no harsher than before even though I lowered the sidewall profile and added Hotchkis springs. The other suspension bits include full poly bushings, Bilstein shocks, and an adjustable panhard from Hawks. The Hotchkis/Bilstein combo work surprisingly well, and the car is a blast on twisty roads.
I bought these during Hawks' July sale. For the sale price, they're an absolute steal. I almost brought them to a shop to have the lips polished and the centers powdercoated Arctic White or Silver, but I'm glad I left them black. I ended up liking the black centers in person, and getting the custom work done would have started creeping these wheels closer to custom 2-piece wheel price ranges. I may eventually get the lips polished, though, as the finish from Hawks faithfully replicates the OEM look but is not quite perfect. I'm detail oriented...
One point of annoyance, though, is sourcing all the other bits: center caps, CAMARO medallions, and lug nut covers. I wanted to get it all from Hawks to support them, but they didn't have the CAMARO medallions (or at least I couldn't find them there) and it was significantly cheaper going to ebay and getting the parts from various vendors. The ebay route also included free shipping in most cases. I think I used Brock's Camaro for the center caps and lug nut covers and Jegs for the Camaro Medallions. What's really funny is I ordered Hawks' Panhard from them via ebay, which was free shipping. If I used their website, no free shipping.
KMK454 is offline   Reply With Quote
Old 01-03-2018, 09:04 PM   #320
Your car looks amazing with the black rims and the white car, good call leaving them as is.
Buddy is offline   Reply With Quote
Old 01-04-2018, 08:13 AM   #321
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Very sharp! The stance looks fantastic.
scholtmj is offline   Reply With Quote
Old 01-07-2018, 10:41 PM   #322
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Stance, wheels, tires all look great! The black centers are definitely the way to go with a white car. I've got the golds with a red car, wasn't sure if I wanted to go gold or black, but found a sweet deal on the golds.
How much did your springs drop the car? The back drop ain't bad either.
V6canvas is offline   Reply With Quote
Old 01-08-2018, 10:15 PM   #323
KMK454's Avatar
They're hotchkis - advertise 1" drop but visually they halved the front fender gap and probably took a third out of the rear fender gap. The net effect is probably about 1.2" or so. I also have Bilsteins in the car. The rear actually sits a hair lower than in this picture. In the picture, the car is on a downhill incline.
Thread Thread Starter Forum Replies Last Post
GTA mesh style alternative? Scorched1984 Wheels and Tires 66 04-16-2016 06:56 PM
15" ta wheels? fcorallo Body 5 08-20-2015 11:28 PM
[NC] FS: Custom C6 Z06 Wheels - polished/gold kah992 Engine/Drivetrain/Suspension Parts for Sale 2 08-19-2015 02:55 PM
trans am gta exhaust question gta power Exhaust 1 08-13-2015 06:15 AM
Fuse for steering wheel controls? 88 gta Keiffer76 Car Audio 4 08-09-2015 11:37 PM
Go Back   Third Generation F-Body Message Boards >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
Vendor Directory
1982 Camaro '82 || 1983 Camaro '83 || 1984 Camaro '84 || 1985 Camaro '85 || 1986 Camaro '86 || 1987 Camaro '87 || 1988 Camaro '88 || 1989 Camaro '89 || 1990 Camaro '90 || 1991 Camaro '91 || 1992 Camaro '92
All content copyright 1997 - 2018 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
