Haltech GM platinum sport
Car: 88 IROC Z
Engine: temporarily stock
Axle/Gears: Stovk
Anyone using the Haltech GM Platium sport plug and play? I've been reading about it, remove your stock computer and plug it in, uses factory harness and sensors. You can add on wide band O2 , and lots of other items.
Just wondering if anyone is using it right now? If so Pros and Cons?
Thank You
Derek
Thank You
Derek
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Haltech GM platinum sport
Platinum Sport GM is an ideal plug-in solution for many popular General Motors engines. Sport GM ECU plugs directly into the factory harness negating the need for any rewiring.
FEATURES:
Direct plug and play replacement of the OEM ECU, no rewiring necessary
Uses the cars factory sensors
Windows 2000, XP, Vista, Windows 7 compatible software
Real time programming, instant hesitation free adjustment while engine is running
Fully user definable 32 x 32 mapping
Tuning via Volumetric Efficiency (VE), Injection time or Lambda Correction (MAF)
Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
Wideband auto tuning using user definable target AFR table
USB and CAN Communication Port
SUPPORTED MODELS:
Camaro V8, 5L & 5.7L 1986-1989 (Injection Type TBI & TPI)
Firebird V8, 5L & 5.7L 1986-1989 (Injection Type TBI & TPI)
Corvette V8, 5L & 5.7L 1986-1989 (Injection Type TBI & TPI)
S10 Pickup 2.5L 1987-1993 (Injection Type TBI & TPI)
Chevy Truck 4.3L, 5.7L, 5.0, 7.4L 1987-1992 (Injection Type TBI & TPI)
Chevy Van 4.3L, 5.7L, 5.0, 7.4L 1987-1992 (Injection Type TBI & TPI)
Holden Commodore VN-VP V6 & V8 (Auto and Manual Transmission)
Holden Commodore VR V6 & V8 (Manual Transmission Only)
Holden Commodore VS V8 (Manual Transmission Only except Series III with AFM)
Holden Commodore Variations: Calais and Statesman
Note: This ECU will require an optional I/O Expansion Kit if you wish to run flex fuel.
The Haltech platinum sport GM has many applications on early GM fuel injected vehicles from 1985 through until the mid 1990s. The sport GM carries the same connector as GMs popular 1227165 ECU (there are a number of other GM ECUs that also carry this connector including but not limited to, 1227303, 1227747, 1227752, 1227170, 1228746, 16198259, 16198445, 16087373, 16198259). There may be many further applications of the Sport GM ECU that are not listed below so this list is not to be considered as comprehensive it is merely a guide for reference:
COMPATIBLE VEHICLES:
gm compatibility
Sport GM should plug directly into all of these vehicles and work correctly, it is worth noting that the Haltech Sport GM ECU does not require the cold start injector, canister purge solenoid, EGR valve, SES light, AC pressure switch nor the Mass Airflow Meter to operate. Elimination of these standard GM components makes for a cleaner installation however it may also conflict with local vehicle emissions legislation that require some or all of these parts to be installed.
The Haltech Sport GM ECU is not capable of controlling electronically programmed transmissions such as the 4L60E or the 4L80E, it is however capable of controlling the torque converter lockup on transmissions such as the 700R (later name the 4L60, do not confuse this with the previously mentioned 4L60E, the E at the end designates that the transmission has an electronically controlled shift points the Haltech Sport GM is not designed to control these electronically controlled transmissions). Transmissions such as the THM400 (Turbo 400) and all manual transmissions require no electronics and are therefore also compatible with the Haltech Sport GM.
FEATURES:
SUPPORTED MODELS:
gm compatibility
1 Post
Transmission: T700
Not cheap, but I figure if you take off the cost of getting a couple of custom chips burnt it may not be too bad.
From what I've read, seems would have to replace the MAF on my 1988 TPI l98 350 with a MAP setup.
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I've had a sport GM in my car for a few years now.
to make it work you'll need a maf car, and you'll need to rewire for the MAP and repin the ECM connectors for the Australian 808 map code.
I posted a how to on this year's ago and for flamed because I didn't use a mega squirt.
My opinion, the haltech has a ton of great options and a GUI (graphic user interface) second to none. And with the newer firmware update you can CAN bus in a e85 sensor and run true flex fuel.
feel free to hit me up with questions, but I encourage you to look up my install thread.
1 Post
Transmission: T700
My car is a 1988 MAF TPI L98 350 and once I finish installing the Dakota Digital VHX dash cluster the Haltech Sport GM is the next upgrade.
Converting from MAF to MAP doesn't worry me, especially if the Haltech auto-tunes.
Another upgrade I'm thinking of is an LS-style coil-per-cylinder setup.
My understanding is that the the Haltech ECM has an optional module to support this, is this correct?
Also, the Dakota Digital VHX digital speed sensor needs to output 2000 PPM for the cruise control and stock 165 ECM. is the VSS 2000 PPM output going to work for the Haltech?
Car: 1963 Holden (GM)
Engine: 1988 Firebird 350 tpi
Transmission: T700
I know this topic is old for you but I am brand new to the whole aftermarket ECU thing so please bare with me.
I have just purchased Haltech's HT-051100 Platinum Sport Plug-in GM.
In a previous forum of yours I read (05-06-2011) "Re Haltech Sport GM, MAF cars come inside", you mention "Loaded in a base map and the car started up almost instantly".
Currently Haltech do not offer any Chevrolet V8 base maps to load in. Do you know if Chevy V8 maps exist?
It is odd that no GM cars are mentioned in the base maps but Holden, Mitsubishi and others are?
Any help with this base map question or any other advice for this Haltech ECU swap would be greatly appreciated.
Regards
